@Gullwing —- you mention several times that you seem to be at a dead end and that the high temps are inconsistent… sometimes at idle the temps come back down to 85-90C and sometimes they stay elevated. As well your troubleshooting has seemed to indicate airflow is working and the sensors are accurate.@gsxr
I have several friends who own E500's and they don't see temp. readings as high as mine in summer. Am receiving the OBD1 code reader in the next few days and am hoping this will shed some light on the issue and point us in some direction. Otherwise am puzzled and have reached a dead end.
Checked the vacuum lines to the EZL. They are fine. One line to the EGR was found defective and has been repaired. Drove the car with a MAF from another car. No impact at all. Checked ignition timing. Also in spec.
Removed thermostat and drove the car with distilled water only and no coolant for better thermal transfer. Also no change.
No symptoms of head gasket failure or water pump issues.
Could the issue be that coolant is not flowing consistently? Could it be that the water pump impeller is slipping on its shaft? This is a common issue with BMW M50 engines of the same era. A water pump w an intermittently slipping impeller would not leak coolant nor would it necessarily have bearing noise.
