OWNER 93-400E (400E)
1992 400E's use thinner 22mm rotors and different calipers. It's possible like your car has the 1992 front calipers... OR, you got the wrong pads (thinner pads are used with the 25mm thick rotors).
Did you have to Dremel the caliper to make the 25mm rotor fit? If so, can you post a photo of the face of the caliper? The numbers on the front will confirm if they are 22mm or 25mm.
Also, what brand / part number pads did you buy?
The caliper says ate 39 2162 and the rotor was too thick. The pads seem fine in there, just the caliper was too thin. I really should have taken pictures but did not. And they are akebono pads 005420012041
Yep, those are the wrong calipers, you have the 22mm thick version.
The correct 294x25mm calipers have numbers 57 and 58 on them. Look for a good used set in a junkyard or on eBay.
Fun fun, any idea how? I know 9/92 is a transitional phase for these but it seems odd.
A previous owner or shop likely replaced the front calipers with the wrong ones... or, they had an earlier car and swapped for some reason. EPC says all 1993 USA model year 400E should have the larger brakes.
FWIW, I had a 1993 400E than was made in the fall of 1992 and it took the smaller brakes.
Interesting data point - thanks for sharing, Jon! It's possible that early production 1993 USA model year 400E's came with the smaller brakes, and that the EPC is wrong... wouldn't be the first time. Oddly, the EPC also shows Euro-spec 034's never received the 22mm-thick front brakes. :scratchchin:
Either way, I'd upgrade to the 25mm-thick brake calipers. Here's a pair for $100/pair with a "make offer" option... no affiliation, etc etc:
https://www.ebay.com/itm/177216009825
https://www.ebay.com/itm/187357863082
Dave, if I recall it correctly, the 400E in Germany always had the larger brake discs. Let me see if I can dig up one of the contemporary tests from a German car magazine to see if my memory serves me well.
Tim, yes, the Euro-spec 034 appears to have started production with the 294x25 brakes. Around the facelift timeframe (MOPF2), Euro 034 then got another upgrade to 320x30mm front brakes, AND also 16" wheels & tires. USA and Japan markets never got the 320mm upgrade though.
USA only, for reasons I'll never understand, started out with the dinky 295x22 brakes which promptly warped at warp speed, which prompted MB to upgrade USA/Japan 034's to the thicker 25mm size.
My car has been getting really bad on warm up with intermittent misfires, code 7 has been popping but it i unplug the battery its pretty fine for a while. I ordered new spark plug wires, but i dont know what else it could be.
scroll back and read post #'s 88-90.
Misfire shortly after reaching operating temp is almost always moisture in the distributors caps. On a budget, cut additional vent slots as shown here. If new Bosch caps are in the budget, cut the slots in new caps (and install new rotors too).
This will only partially help if you have any trace of engine oil at the lower edge of the cap. As mentioned previously, even with slotted caps, the oil leaks must be 100% eliminated to cure the misfire permanently.
Do I need new backing caps as well?
The insulators would be good to replace as well, but if the back side is dry (no liquid residue), you can probably leave them alone.
So I just need a camshaft end seal replaced?
Only if leaking. The cam seals are not a common leak point, but check to make sure.
The cam advance solenoids, however, are leaking on pretty much every M119 that hasn't yet had them replaced or resealed as shown here. It's not expensive but requires a lot of hours of labor.
Although I think I just need to check the part, it seems like I might need a new rotor bracke for proper fitment. Is this true?
This is VERY unlikely. Search the forum for photos of the old-style rotor bracket. The old ones are crazy rare. Most cars were upgraded to the late style rotor bracket many years ago. Easy enough to find out, remove a rotor and check the bracket part number. They are visibly different.
How do I know how much oil im going through? My dipstick was at just above full and now at half.
Keep monitoring the oil level and note the mileage on the odometer. "Normal" is about 1 quart per 3000 miles or better. If burning a quart in 1000 miles or less, that's concerning.
The oil level should be at the middle of the dipstick. The Mercedes levels are not "Full and Add", they are "Max and Min"... these are not the same. At oil change time, add 2 gallons only. This should result in the level being in the middle to slightly above the middle. Do not add oil until it gets to the MIN mark. The low oil level light on the dash will turn on when the level gets a little below MIN.
Read this document for more details on how to properly check oil level.
Just got my oil changed. Used Amsoil 5w-40 Euro FS with 8.5 quarts. I was curious if I could use signature series next time or if I should stick with this due to the MB229.5 cert and the signature not having it. Also the 8.5 quarts is at slightly over middle on the dipstick.
Amsoil is good stuff. Don't worry about the MB certification, it's kinda irrelevant on early 1990's engines. Remember to check the level when hot, and follow the instructions above.
I think at least one of my fuel pump has gone out. There was a whining sound and low chuggy idle. Can I just replace the pump or just do it all.
First make sure the fuel pump relay isn't clicking at idle. This is located below the rear seat, passenger side.
If the fuel pumps are old or original... replace both of them, and only buy Bosch from a reputable vendor (AHAZ, FCP, RME, Rock Auto). There are some counterfeit Bosch products out there. If the high pressure hose exiting the pump is not fairly recent OE, I'd strongly consider replacing that as well. It's expensive as hell though, as you should only buy the OE/dealer hose. The aftermarket hose is like 1/4 the price but people have reported them failing in 1-2 years. When that hose leaks it is a major fire risk. Don't pinch pennies here.
Everything you need to know, including part numbers, and other recommended items to replace, are in this epic thread:
The big hose from the fuel tank to the pump generally does NOT need replacement unless it's excessively cracked.
I added everything into a cart already. This is just my daily so it cant be out for too long, so just do everything in that region. Also, this occurred a week after changing the fuel filter.
I was curious about the throttle cable 1243006630, should I replace this along with the guide as preventative maintenence or just wait until I have a problem with the cable and replace only the guide.
If not damaged, you can leave the throttle cable alone. It's not a common failure.
I replaced my valve cover gasket again and it still seeps. I torqued to 9nm I believe. I had no sealant on the first one and I do have sealant on this. Does it maybe have a microcrack.
These can be a PITA to seal properly.
What brand gasket - dealer, or aftermarket?
New copper seals on the bolts?
Normally you want to use NO sealant. What sealant did you use, and was it on both sides, or only 1 side?
Are you sure the E420 got 16" wheels? I've never seen this before, and checking the ones for sale on mobile.de now they all seem to have 15" wheels..
PS: I realize that this does not equal proper research, just curious to learn more here.
Elring gasket, i forgot to get new washers (part number?) And it was that victor reinz sealant
Late production, European-market E420 did indeed get 16" wheels along with 320mm front brake calipers/rotors.
USA and Japan never received that upgrade.
:rip:
There have been reports of the aftermarket gaskets not sealing well. The OE gaskets were reasonably priced, before the kits went NLA and you now have to buy the pieces separately. I usually see Victor v/c gaskets, not Elring. Was there a COO on the label?
What Victor sealant exactly? Got a photo of the label or a part number?
