119.980 cam cover seals originals NLA.
Rainz500
New Member
Hi,every discussion here about cam covers seals say-use only original seals! Today i asked our local MB dealer about seals and they say,that seals is no longer awaylable and only way is to buy them,is with cam covers 850.- eur per side! OMG. Even FCP sell only Elring or Reinz. So,what are my options here-use Reinz and hope,they will not leak or use new Reinz with some sealant?
Read here on topics,that people suffer Reinz seals leaks already after 3-4 months! Thank you.
This is incorrect information, I believe. The valve cover gaskets are still available from the dealer, but the 5 pieces are sold separately, instead of in a kit. The supercession data is NOT clear.
Elring or Reinz may be worth a try but DO NOT add any sealant!! Remember to replace the copper washers under each of the 9 bolts.
More info here, the main gasket is the same for .97x and .98x but you will need different round donuts for the .98x engines:
Thank you,sir!
