FOR SALE 1992 400E, Pearl Black/Cream/Black, 154kmi, Cars & Bids auction (Cantonment, FL)
Dr. Solomon
E500E Newbie
New Member
VIN = WDBEA34E5NB763264
Datacard: https://www.lastvin.com/vin/r1M9Wdwe0pq2qgNvD
https://carsandbids.com/auctions/3BDmOyk4/1992-mercedes-benz-400e?c=all
1992 Mercedes-Benz 400E​
No Reserve 4.2-Liter V8, Sunroof, Mostly Unmodified
Highlights​
THIS… is a 1992 Mercedes-Benz 400E, finished in black with a black and tan interior.
  • A partial list of notable equipment reported by the seller includes 16-inch wheels, headlight wipers, a sunroof, power-adjustable front seats, automatic climate control, and cruise control. Notable modifications reported by the seller include reupholstered seats.
  • Mercedes-Benz introduced the W124 for 1986 as a replacement for the W123. At launch, the range included the gasoline-powered 300E and the diesel-burning 300D; additional variants joined the range later in the production run. Mercedes-Benz turned the W124 into the first E-Class for 1994, the new name was notably accompanied by a more modern exterior design, and production ended after 1995.
  • Power comes from a 4.2-liter V8 engine, which produces 268 horsepower and 295 lb-ft of torque. Output is sent to the rear wheels via a 4-speed automatic transmission.
Equipment​
A partial list of notable equipment reported by the seller includes:
  • 16-inch wheels
  • Headlight wipers
  • Sunroof
  • Power-adjustable front seats
  • Automatic climate control
  • AM/FM stereo system
  • Cruise control
Modifications​
Notable modifications reported by the seller include:
  • Seats reupholstered in black vinyl and tan synthetic suede
Known Flaws​
  • The attached Carfax history report indicates that this Mercedes was involved in an accident involving front or side impact in April 2009 that resulted in "minor damage" to the left side and left front. The airbags did not deploy.
  • The seller reports that the tachometer previously stopped working and was subsequently repaired. As a result, this 400E is listed as True Mileage Unknown or TMU; its odometer currently displays 153,700 miles.
  • Various chips, scratches, scuffs, dings, and bubbling paint around the exterior
  • Broken passenger's side exterior mirror and chips on windshield
  • Worn finish and curb rash on wheels; bent driver's side front wheel
  • Scratches and cracks on wood interior trim
  • Loose stitching on center armrest, separating headliner, stains on carpets, and peeling door sill trim
  • Damaged front wheel well cladding, damaged underhood insulation, and hole and rust in spare tire well
  • Some rust on trunk pinch welds and on underbody fasteners
  • The seller reports that this 400E intermittently misfires and has a hard start after being driven; the seller also reports that the driver’s side valve cover is leaking, the front plastic underside panel is missing, the passenger's side edge tail light and radio do not work, the air conditioner does not blow cold, the driver's side window makes a popping sound when rolled down, and the front driver’s side wheel hub has worn threads and only 4 lugs will thread.
Recent Service History​
Service documentation in the photo gallery indicates that the following maintenance has been performed:
  • April 2022 (145,531 miles): 4 tires replaced
  • October 2021 (143,640 miles): Alignment performed
The attached Carfax history report shows that the following services have been performed:
  • May 2025 (153,612 miles): Engine oil and filter changed
  • September 2024 (151,739 miles): Engine oil and filter changed
  • April 2023 (147,669 miles): Engine oil and filter changed
  • October 2020 (141,047 miles): Engine oil and filter changed
The seller reports that the following services have been performed:
  • Brake pads, brake rotors, shocks, front strut mounts, front tie rods, drag links, and steering damper shock replaced
Additional service history is detailed by documentation pictured in the gallery and in the attached Carfax report.
Other Items Included in Sale​
  • 1 key
  • W124 Bentley service manual
  • Full size spare wheel
Ownership History​
The seller reports that they purchased this 400E in August 2018 and have added approximately 23,000 miles since.
Seller Notes​
The seller reports that this 400E was repainted in the past in its factory color, and that the hood, trunk, and doors have been resurfaced.
As you said, lot of work. Price reflects it.
+1. Despite the seller's claim to the contrary, this is a running/driving project car. It needs a LOT of sorting out.
Price seemed reasonable-ish assuming the buyer was local and not tacking on $2k for transport to the opposite coast.
Agreed with the above - it was good that the seller pointed out all of the flaws and seemed straight up and honest! Somebody will have fun fixing that up.
