  • NOTE: THIS FORUM IS ONLY FOR 400E & E420-SPECIFIC PARTS. IF THE PART YOU ARE SELLING IS ALSO USED IN COMMON WITH THE 500E/E500, PLEASE LIST IT ONLY ON THE 500E "PARTS FOR SALE" SUBFORUM. DUPLICATED LISTINGS ON THE 500E & 400E "PARTS FOR SALE" SUBFORUMS WILL BE IMMEDIATELY DELETED.
    DISCLAIMER
SOLD 1993 400E parting out (Victoria BC Canada)
DLL
Near Victoria BC Canada.
Car did run (poorly) and move on its own power when I got it last summer.
It was rusty and beat on. Interior was good surprisingly.
I'm keeping a few things.
Will ship smaller simpler stuff North America.
At this date, sold:
  • Interior except dashboard and steering wheel
  • Engine related modules
  • MAF and Wiring harness, misc.
  • All burl wood
I'm also open to suggestions on things worth keeping. I have an E420 and a W124 Coupe. I'm thinking the cluster - for a manual swap on the coupe, also brakes, Sway bars, LCA's etc.
The main catalyst pipe is worth keeping as a spare (or, selling) if the factory cats are intact. Crossover pipe is also NLA. If you have an E420, there's quite a bit to keep as spares, if you have storage space. The transmission, for example...
Fortunately (or unfortunately!) I have a fair bit of storage space
I could use the drivers side vertical piece of plastic that holds the under tray/splash guard onto the frame. I researched and couldn't find a part number or diagram.
I believe the power steering fluid leaks onto these an with time corrodes the plastic.
thank you...
San Diego, Calif
thank you...
San Diego, Calif
I’m away right now, will look next time I’m under it
thank you...
San Diego, Calif
This?
Hi, are you able to remove the transmission mount and check its condition? Likewise, if that is good, then I might purchase more parts to make the transaction worth it for both of us.
I don't think so.
Not until if / when I pull the drivetrain.
That's not likely to happen soon
At this date, sold:
  • All burl wood
I would like the air tubes if they are in good condition and the battery cover
Any chance you have the insulated parts of the exhaust system still? (Main catalyst pipe, and crossover pipe.)
Looking for complete pieces, not just the insulation. 😅
