  • ATTENTION
    Thank you,
    Management
SOLD 1993 500E, Pearl Black/Black, 144kmi, BaT auction (Fremont, CA)
gsxr
No affiliation. Previous ownership history in this thread. Sold for $34k with fees, see post #4 below.
Some good stuff here. BOTH harnesses replaced, rebuilt transmission in 2020 ($3k invoice), and - gasp - correct 500E Euro headlights! :yahoo:
From a quick glance through the photos, the only real concern is potential rust in some areas. For example, look at the rubber drain grommet in the spare tire well, and the bubble below the tunk badge. I'm surprised the exhaust system still has all the heat shields intact. The blank headlight wiper panels need paint, ideally the new owner would add the correct headlight wipers for the chef's kiss on the front end. Needs a full repaint unfortunately, which will hurt the sale price a bit. Antenna may have issues, note it is not fully retracted (relatively easy fix). Needs mirror booties also. Headliner needs replacement. Engine splash panel missing (NLA).
VIN = WDBEA36EXPB941055
Datacard: https://www.lastvin.com/vin/mPD91djWWG7ElrNM3
This 1993 Mercedes-Benz 500E is powered by a 5.0-liter V8 paired with a four-speed automatic transmission, and it is finished in Black Pearl Metallic over black leather upholstery. Equipment includes 16″ eight-hole alloy wheels, a sunroof, heated power-adjustable front seats, a cassette stereo, automatic climate control, and cruise control. Purchased by the current owner in 2017, this 500E is offered by the seller on behalf of the current owner with service records, a clean Carfax report, and a clean California title in the name of the owner’s LLC.
The 500E was assembled by Porsche and features wheel arch flares, revised bodywork, and a lower ride height when compared to other W124 models. This example is finished in Black Pearl Metallic (199), and exterior features include fog lights, a sunroof, a power-telescoping antenna, and a single eccentric-sweep windshield wiper.
The 16″ eight-hole alloy wheels are fitted with BFGoodrich g-Force Comp-2 tires that were mounted in 2025. Braking is handled by anti-lock discs at each corner.
The heated power-adjustable front bucket seats and rear bench are upholstered in black leather along with a color-coordinated dashboard, center console, door panels, and carpets. Wood trim accents the dash, center stack, and doors, while amenities include automatic climate control, cruise control, and a Becker cassette stereo.
The steering wheel frames VDO instrumentation consisting of a 160-mph speedometer, a 7k-rpm tachometer, an analog clock, and gauges for fuel level, coolant temperature, and oil pressure. The six-digit odometer shows 144k miles, approximately 35k of which were added under current ownership.
The 5.0-liter M119 V8 was factory equipped with Bosch LH-Jetronic fuel injection and was rated at 326 horsepower and 354 lb-ft of torque when new. The upper and lower engine harnesses were replaced in 2015. The distributor cap and rotor were replaced in 2020, and the fuel filter was replaced in 2023. The car most recently passed a California emissions inspection in November 2025.
Power is routed to the rear wheels through a four-speed automatic transmission that was replaced in 2020. The Carfax report is free of accidents or other reported damage.
I have record of this car in my personal/private database, dating back to April, 2006. At that time, the car was residing in Heath, Ohio and had approximately 110,000 miles on the odometer. The car was listed for sale on eBay.
My private database comments are as follows: "Seller says is third owner and car is a daily driver; says that has new tires; ignition caps, rotors, plugs; transmission and oil service; seller says "car has had very minor paintwork on the front end, it is great work and the only way I found it is with a paint gauge, there was no structural damage, and I would assume it happened early in the cars life. There has also been some touch up work on the pass side where someone brushed against the car the day I picked it up"; also CE light comes on regularly with code 5 (EGR he says) which resets for a while. German Zoll plate on front; otherwise car looks decent."
eBay auction captures from 2006 are attached.
  • 941055.pdf
    941055.pdf
I thought this would bid higher, or end RNM. Sold for $32,250 which is a bit under $34k with fees, figure high $30's with TTTT added. Maybe the potential rust scared aware a few people? Lousy time of year to be selling a car though, that didn't help.
High bids:
$32,250 bid placed by Spider88
$32,000 bid placed by EU-Cars
$29,000 bid placed by GusBuss
$27,000 bid placed by Foghammer650
$24,250 bid placed by gharoyan
$22,250 bid placed by shhnnozy
Yeah I agree...pretty low and I'm not sure the timing would influence it so much. Hard to guess what scared people away especially with the one going for 77k last week.
Unfortunately, I didn't get to see the car on Saturday but from pictures it looked like a real clean example.
The market is market even if it's bat, xmas is not the time of year for a higher mileage toy... a low minty one, probably
An interesting tale honestly, I got mine at 127kmi and a friend got a new S63 at the same time.
We were bored but he has more money
High bids:
That and also think the MBMarket @benzgarden car stole some of it's thunder.
