  • NOTE: THIS FORUM IS ONLY FOR 400E & E420-SPECIFIC PARTS. IF THE PART YOU ARE SELLING IS ALSO USED IN COMMON WITH THE 500E/E500, PLEASE LIST IT ONLY ON THE 500E "PARTS FOR SALE" SUBFORUM. DUPLICATED LISTINGS ON THE 500E & 400E "PARTS FOR SALE" SUBFORUMS WILL BE IMMEDIATELY DELETED.
    DISCLAIMER
WANTED 1994-95 OEM Side Blinkers & Engine Splash Shield
smoker
Active member
Hi
Require good quality OEM side blinkers & plastic splash shield for 1995 E420. Shipping will be to CT 06877
Blinkers should be available from AutohauZ or FCP Yurro or RM Yurropean new. They are not horribly expensive.
Splash shield? You mean the sound encapsulation panel under the engine? I believe those are NLA from MB, although you may be able to find a used one from a forum member.
Links to one of the facelift blinkers, made by the current OEM (Automotive Lighting, which used to be Bosch/Magneti Marelli):
Yeah. Mine got stolen or lost by the garage which was working on my car. ENI Motorsports is doing last of the moping up and just require these few things.
Thanks for the link :)
As an FYI, the Euro facelift turn signals are a bit cheaper. These are clear (no yellow section), are made by Hella, and available from your favorite dealer. P/N 124-826-09-43 and 124-826-10-43.
Roughly $150/pair delivered, instead of $200+ for the pair.
:124:
@smoker, Just as info only. The original side marker plastic tends to deteriorate from age. It’s possible that the clips will brake and the light will fall out when you’re at speed on the freeway or road. It happened to me on my long gone 86-300E.
Happened to me last week (but that's 'coz the mechanic did not re-install them properly) and was flapping in the wind for approx 100miles @ 65mph (no rest area to pull over) and scratched the paint :cry:
Happened to me last week (but thats coz the mechanic did not re-install them properly) and was flapping in the wind for approx 100miles @ 65mph (no rest area to pull over) and scratched the paint :cry:
I went ahead and purchased a brand new Automotive Lighting headlamp set for $500 off the bay, because the old blinkers were cracked all over, and then, out of the blue, the right one fell out. I prefer the “new” look compared to what I had before.
They’ll come off in a few weeks as the car goes into the body shop.
