No problem Nocfn, it was great having you on "speed dial" to sort this out. A big THANK YOU to
@Jlaa for the wrenching company, conversation, and help to sort this out. We followed
@a777fan awesome guide on the facelift blower motor replacement guide.
There is already an awesome write up by user ‘makemann’ on how to do this job on a pre-facelift car, but I thought I would attempt to chip in by sharing my experiences on a 1994+ w124, which has a slightly different regulator installation. Note: I did not actually end up replacing the regulator...
www.500eboard.co
I haven't checked recently but I think the facelift (1994) blower motor regulator OEM part is still NLA. That leaves you with the KAE option but it is typical of aftermarket parts in that it is NOT quite a drop in (Nocfn's post reminded me to check the heat seat holes).
You can see the KAE heatsink is thinner than the OEM one (OEM on the right):
That means of couple of things (and trust me
@Jlaa and I learned this the hard way)
1) The heatsink screws are M5 x 0.8mm torx head bolts. Who know what the KAE holes are but the for sure are NOT M5 x 0.8. So you need to a) drill the tapped holes deeper (I used a 4mm drill) and then follow up with a M5 x 0.8 tap.
Since the KAE part is not quite dimensionally correct, you also need to do a bit of plastic filing here:
KAE also has crappy crimp quality, thankfully this crimp released when we had to disconnect the fan after a test, and we were able to re-crimp it, so check those crimps.
Several hours later (thanks for your patience
@Jlaa ) re-install is complete, but now I need to order new cabin air filters, and some missing bits.
Here is the Proof of Life, my new blower motor fan spinning!!
@Jlaa spent 99% of the time on my car, and then he spent 5 minutes lubricating his wiper shaft with Molykote 33 light after removing the shaft extension cover and stopping the wiper in the vertical position.
@Jlaa car looks amazing as usual and deserves a 500eboard round of applause for helping me out. We are now available at $400/hr as a team to replace your blower motor but I think we can do it in an hour now after learning how to do it all day today! (not including the lunch break where we had fun driving the little BMW Z3)
