SOLD 94-95 Becker radio/head unit and amplifier
Quick4door
Removed from 94 E500. BECKER BE 1492 hesdunit with code. Was going to swap this into my car but ended up finding the correct Becker Geand Prix.
Factory amplifier for the above radio- will only work for 94/95 models with the Becker BE 1492 head unit.
$110 shipped in CONUS for head unit.
$50 shipped for the amp in CONUS.
Will combine shipping, PM me.
Andy
Just FYI - the single amp is for the "Active Bass" setup used on low-end sedans, all wagons, and the cabrio. Most other models had a dual-amp setup referred to as "Sound System". Same 1492 head unit was used with both setups.
:gsxrock:
Thank you guys, I do appreciate the clarification. I was under the impression that the single amplifier was for the later 94/95 models.
Both the BE-1432 (two-piece) and BE-1492 (facelift) stereo systems used a dual-amp setup in the 500E and E500, respectively.
HOWEVER, the amp pairs are different and are not interchangeable between the two different Becker systems.
The single amplifier was not year-dependent. It was used from 1991-1995 but only on models with "Active Bass".
Dual amplifiers (each one smaller, different p/n) were also used from 1991-1995 but only on models with "Sound System".
All 034/036 in North America had Sound System as standard equipment, but this was an optional extra-cost item in ROW.
:gsxrepc:
