FYI ASR Precharge pump - REPAIRED
canyoncarco
Moderator edit: pump was repaired, see post #2 and #4 below.
Hello all! Just like the title says I am looking for a ASR precharge pump M15 that is underneath the reservoir. Thanks in advance
Manny
Hello canyoncarco,
Did you take pictures of the dismantling, cleaning and re-bleeding?
Thank you in advance
Hello canyoncarco,
I did. Here are some of the precharge pump. It was taken apart and brushes were cleaned. The picture with the blue arrow is after cleaning. I have a video as well of the bleed. I will have to look for it.
I would love to see a full detailed how to on this to show the electrical side of things
and cleaning the old gunky brake fluid out of the pump where the proper bleeding
procedure has not been done in years.
This would be of benifit to so many models of this era
With some of the high pressures involved its not something to just steam into
Graeme Johnson
As an aside, if you're looking to clean a motor commutator, don't use an abrasive such as emery cloth. Why? The small particles of the abrasive will come off of the paper backing while you're using it and can become embedded in the soft copper of the commutator bars. This turns the bars into little grinding wheels which will wear the brushes down quickly.
There are commutator stones that can be used on the commutator bars with the armature mounted in an electric drill. That's the preferred method.
