I have to replace the cam adjuster solenoids in 1990 M119......the only ones available are 1190510077.
Does this require a replacement armature??
There isn't any clarity.
Do I need the 1110510043 OR 1190510043 ? or do i even need to worry about it?
05-2175 chart specifies if you install solenoid 119 051 00 77 then you must install armature 119 051 00 43...BUT some have suggested that if you install119 051 00 77 then install 111 051 00 43......which is it ???
OH..and...they sales guy at Pelican said that he has no notes associated with 119 051 00 43 solenoid that says you have to replace the aramture...or at least there is no note even mentioning the armature.
Can someone please clear this up so I can finish this job....please.
