Defrost
CB500E
Is it normal operation for when the hvac controls are set to defrost the fan automatically sets to the highest setting and the temperature will go to the highest temp regardless of temp setting?
It is very annoying. I want defrost because it's pretty wet here in Vancouver so I need the defog but I don't need the African heat emitting from the vents.
AC on , why don't you just distribute air to windscreen with your desired fan speed and temp ?
Use the defog setting if you don't need max heat & max fan speed. On ACC, this is the button next to defrost (button 2 of 5, left to right).
:mushroom:
