@Benzy Boy Since you do not need any emission tests, might as well replace both cats, unless you want to do a 2-into-1 cat like 2phast did and his exhaust sounded good.
As far as which cats you should choose, it depends on how much you want to spend, just make sure the cats have a metallic substrate vs. a ceramic substrate and the cats have a good track record. I ended up using 200 HD (High Durability) cell cats from HJS in Germany. They make very high quality cats that can withstand any type of abuse and the ones I got are made to handle 640 whp (320 whp each cat) with no problems. It’s an all steel cat (shell and substrate) with the substrate being triple wound for additional strength and the substrate is brazed inside to the shell. It’s brazed at the both ends and center of the cats shell is slightly cringed, where the substrates is also brazed inside to the center of the shell. This keeps the substrate from telescoping under heavy usage. Basically, these cats are made for supercars level of spirited driving on the Autobahn. These cats are directional, so when installing them, the arrow on the cats outside shell needs to point towards the rear of the car.
I got the HJS cats from Fabspeed Motorsport in Pennsylvania, U.S., where they welded on the end caps, as the HJS HD cats are no longer sold in the U.S. as full cats and I’m not sure about their availability in Canada. Fabspeed Motorsport buys the cores directly from HJS and will weld on the end caps. These cats are not cheap, but they are made to last. I ran my whip at many autocross events, as well as over 200 drag races without any issues whatsoever. Bellow is what paid for the cats, but that was a while ago.
Btw, Kooks green cats looked promising, until I read more than a few reports of them failing prematurely.
