ETA Relearn?
luckymike
I've just finished rewiring the ETA from my 1995 E420. I have heard that there is a process for the ETA to relearn its settings but I can't seem to find a consensus from my research.
Anyone have a definite process for resynching the ETA?
Make sure you have a good and decently charged battery. Turn the key to the run position, but don't crank or start the engine. Leave the key on for at least 90 seconds. That's it. If you have the hood open and you are listening, you will probably hear the calibration take place at some point in time during that 90 second period, usually fairly early into the process. You'll hear a little change in the character of the buzzing noise emitting from the actuator, followed by at least one, and on rare occasions, two distinct metallic "clack" sounds as a the mechanical end stops of the throttle plate are "learned" by the control unit...
Thank you, Klink. I appreciate it.
nocfn: Yes and no. I have a couple pics but mostly it will be commentary.
