I'm in the middle of installing a FGS valve body. I was able to get the pan off with the exhaust crossover pipe in place but getting the pan back with the pan gasket in place is not possible. I can loosen up the lower bolts on the crossover pipe but the upper bolts are making me nervous. I'm scared to death they are going to break if I torque on them. If they break I would be forced to remove the entire exhaust manifold to remove them. I can get masterblaster on one of them but I don't see a good way to soak down the bolt closest to the block with masterblaster.
Everything is back together except the pan.
Any suggestions? Experience with these bolts? Thanks.
