FS: 1992 500E, 199 Pearl Black/Gray, 95kmi, $13K (Denver, CO)
For Sale, 1992 500E 199 Black over Grey Leather 95K Miles, Looking for a quick sale, first offer close to 13K will be accepted.
Car is in very good condition, I am the 4th owner. I have records from owners 2 and 3 available for interested parties. Car is great but isn't the best car for a snowy climate and frequent trips to the mountains.
I have Carfax and Autocheck Available for interested parties. In the interest of full disclosure, this car recently had a PPI done which determined that the hood, radiator support and right front fender have been replaced. These were NOT noted in the PPI I had done when I was looking to purchase the car. The car is straight and drives fine, there are no records of the repairs so I can only assume this is something that occurred with the first owner and I have no records for that person. I have adjusted the price to reflect this fact and I am open to offers.
Here is a list of service completed on the car since I have owned it.
01-03-14 Shifter Bushings replaced
01-09-14 Oxygen Sensor Replaced
06-06-13 Drive Belt Tensioner/Tension Rod
06-01-13 New Thermostat, Thermostat Hose, Upper Radiator Hose, Coolant, Overflow Reservoir, Coolant level sensor, Mechanical Fan Clutch
12-22-12 Transmission Filter/Fluid Replacement, Oil Service, R&R Lower Oil Pan Gasket, Replace Oil Level Sender and Oil Pump Pickup, Differential Fluid Service (83.5K)
07-01-12 Replace Spark Plugs and Rotors (83K)
06-12-12 Paint Panels for Euro Headlight Washer Install
05-21-12 Clear Blinkers, Headlight Wiper Motors, Parts for Install
03-05-12 Brake Fluid Service, Replace Drive Belt/Tensioner, Engine Mounts, Repair Line to Washer Nozzle, Replace Power Steering Pump, Replace Exhaust Hangers, Repair Vacuum Lines to Engine
Recommended service from the PPI conducted recently suggested shock mount replacement (due to age/cracking) and re-seal of power steering box (slight weeping)
Wheels are from a E430 sport model, with 245/45/17 Continental DW tires which were purchased in June of 2012. They still have good tread depth and are great summer tires.
I have ALL ORIGINAL headlights, wipers, turn signals and tail lights in case the buyer is interested in bringing it back to stock condition. I also have a spare LH module and timing chain (NIB) available to the purchaser included with the car.
Pics of the car can be found here. https://www.icloud.com/photostream/#A15oqs3q2bDgt
PM me for any questions you may have and additional information.
