FOR SALE Lorinser LM-1 18 X 9 ET 44 Used Set of 4 in very good condition $3K OBO
Perhaps, But if they correctly fit / were removed from my 1998 SL 500 which generally has the same running gear and fender clearance as the W124.036 (correct me if i'm wrong) They will / should fit
I'd have expected a 9.0 ET44 wheel to touch the strut tube up front, unless spacers were installed.
I guess they do have spacers already bolted to them
Nice looking R129!
Looks like a 15-20mm spacer. Do you have the extra-long lug bolts to include with the wheel sale?
Lorinser wheels can come with their own spacers as these have. They made wheels that work on S Class, or R129 I believe. I'm guessing they are 12mm, for an effective 32et, same as my Lorinser set up. Mine are held in with a tension ring. I've never seen them bolted on.
+1 on the R129
OE lugs will fit the AMG wheels, although you need specific OE lug bolts if you want the heads to be flush with the wheel face.
The Lorinser bolts should have a longer shank length vs OE. Do you have the special / longer bolts for the Lorinser wheels you are selling?
:watermelon:
The same lugs that came in the Lorinsers Are seated at the same depth even with the spacers as they are on the Monoblocks…
and those lugs are seated at the same depth as they were on my old 500E... and ALL pics of the lugs are seated at the same depth as what came on a factory e55
The lug on the left is the one in question. Should he same length / crown height as everyone’s on this site … right one is W140… it has that tall crown to take lug to wheel face
