Stephan,
Thanks for explaining DAB to me although it seams like a step backwards. A political 'Lobbiest' must have money invested in the DAB system and is creating a new electronics market by making FM obsolete. What other reason could there be if you are truly losing radio reception. The DAB or DAB+ sounds like a patch fix something like putting 'Rabbit Ears' on top of your TV for better reception.
Switching gears, On the US - HVAC vs Euro. The manual controls sound great but as discussed here would be a PITA job to convert a US car.
In defense of our Automatic units, I think they work fine as long as they are in top notch condition and running on all cylinders. If one component is not giving it's ALL the system SUCKS.
Living in SoCal where it will be over 100F today is a real test of the AC and mine at least has been up to the task in the past and I have an 040 car. I will say a black car parked outside on a hot sunny day is hard to cool down quickly in short distance drives. It will take approx 15 minutes at least and if your running errands and are in and out of the car it will never be real cool. Once the car is cooled down I have found that if the temp wheel is set on MAX cool I can set the fan speed to low and the recirculate cabin air switch is turned on, the interior can be a very comfortable environment.
Also once cool you can fiddle with the temp wheel if you want and get the fan to slow down to about medium speed.
All in all I think the US system works fine as long as it's 100%.
....its all quiet...weekend ,,fiddling around with the EvoLtwin..."laughs
