FOR SALE M119 Aluminium Finned Oil Pan for 500E, 722.3 ATF Pan.
NIIBE
M119 Aluminum made heat treated Oil Pan for 500E. Reduce oil temp. Proudly Made in Japan.
Photo is for Domestic Japan sale with oil and filter.
Export is not include Oil, Filter, level sensor, rubber and gasket etc.
Oil pan and drain Bolt, pan bolt only.
1000USD+ shipping
How to make Oil pan. see my Blog
Export is not include ATF Oil, Filter, level sensor.
Oil pan and drain Bolt, pan bolt only. with Silicon O ring. No leak !
1000USD +shipping
Crazy about ATF pan ! see my Blog.
My name is hidden inside !
@NIIBE , are there extra threaded ports that could be used for an engine oil temperature sending unit? If so, what is the thread diameter / pitch (i.e., M14 x 1.5, etc)?
Also - is the capacity the same as original, or is the engine oil pan deeper?
:wahoo:
:wahoo:
 gsxr Thank you for your comment,
The left side is for Oil cooler out AN8 hole, right side has also same AN8.
As you know, JP and US version do not have genuine oil cooler outlet at oil filter housing. and EU vesion is NLA.
Also such oil cooler has Friction for pumping and thermostat.
These two L&R holes are useful who want to add Electric oil pump and cooing core.
The upper side of middle is drain hole M14x1.5, you can use existing drain bolt with cupper wassher.
The lower side is Oil temp sender hole. 1/8 PT, you can use common oil temp sender.
The Oil capacity is around 0.5L higher than stock one, but regarding thermal expansion of Large amount of oil,
I thought that around 8.5L is maximum.
Here is the photo with ATF pan and Oil pan, very good for cooling !
Speed Niibe
Beautiful!!!! I love the added ports.. If and when we put the track car back to work I'll be calling you;-)
jhodg5ck,
You can see the molding inner wall for G!, when you rolling by cornering, or Braking, and Wheelie
Oil shall be moved by its G.
So I refer and studied from Subaru Impressa WRC Oil pan, and modified 5 wall around oil suction.
Hope you can enjoy these hidden wall inside of Niibe Pan.
Here is the picture of mold before making sand cast.
Oil/ ATF pan also has Temp sender and Electric oil pump outlet/inlet.
Regards,
NIIBE
M119 Niibe Oil Pan and 722.3 ATF Pan are all sold out. Now out of Stock. but may re produce within a few month.
722.6 ATF Pan are still available.
same as O ring gasket use, no sloppy leak like genuine Rubber pinch type gasket.
For whom M119 Niibe Pan with NAG1, 5speed 722.6 trans.
Speed NIIBE
