Received - thank you very much, Sir !!US 1994 E500 sticker just emailed
It's likely that your car is from a dealer that moved or changed owners, and then was assigned a new number.
Part of the problem with my list in the Wiki is that it is a relatively current list, not the list that would have covered all of the dealers back in the early to mid 1990s. So, a lot of the numbers have changed.
I've never been able to get a comprehensive list of dealer numbers from "back in the day" when our cars were new, unfortunately. I've tried a number of sources.
Clearly, you need more vehicles to wrench on...Should be a nice project, however.
No, it won't. That booklet is a consumer-level booklet (and I have at least 30 of them in my collection, from various years) that just illustrates to owners where their nearest stealerships are, or are located in case they break down whilst traveling. These booklets mainly contain maps and address data by state for the current dealer roster at the time.
What I'm looking for is a list of five-digit MBNA dealer codes that was used internally by MBAG and MBNA to reference specific dealers.
I do have the examples of the window stickers that I need. They are scanned and I am (slowly) in the process of putting the first, sample, window sticker together. Preparation of each sticker is going to be around 4-5x the amount of work required for a data card, due to the specifics for each car and the amount of text that has to be formatted for each sticker.
Are you still pursuing this project? I just found my 1995 sticker ticked in the owners manual.I've received a couple of dealer windshield stickers for E500Es from folks.
Many thanks to those who have sent. I would like to get additional ones for reference, particularly from a 1994 model if possible.
It's not going to be that big of a deal to create these windshield stickers. However, they won't be truly accurate unless/until I know the location where the car was brought into the country at; the prep center before it was sent to the dealer; and the selling dealer's name. That's the kicker.
There are only a limited number of ports of entry, so this is not a huge deal. The biggest deal is the selling dealer. The best place to find that information is in the first stamps in the service booklet, if you have yours available. The selling dealer will also give a good idea of where the prep center was for the car.
If you have a VMI (Vehicle Master Inquiry) for your car, then you can look for the "Selling Dealer" place, and it will provide a five-digit code. For my car, from its VMI, this Selling Dealer code is 05721.
The Wiki provides a list of these codes and their corresponding dealers. This list is here: https://www.500eboard.com/forums/wiki_index.php?title=Mercedes-Benz-USA-Dealer-Codes
In my case, there is no dealer with code 05721, so this means that my car's original selling dealer either went out of business, or it changed hands and/or moved and was issued a new code. All of the other dealerships with "057XX" dealer codes reside in Southern California (between LA and San Diego), so it's very very likely that my car was sold by an Orange County dealer when new.
I'm going to create a dealer windshield sticker for my car in the coming weeks, and post it here. If folks like what they see, then I'll move for additional graphics, production and process improvements and move the windshield stickers into production. At that time, I'll have a better idea of what I'll have to charge for them, but it will likely be in excess of $100 per windshield sticker, because of the time, expense and oversize postage involved to ship the windshield stickers to keep them flat. This is going to be a significant up-front investment of many hours.
Yes, but the only ones I've seen are expensive... like $100-150. I haven't found a lower-cost option yet. Also not sure how accurate these are - where do they get the data for vehicles with lots of a-la-carte options, like most W211 chassis for example?Does anyone reproduce the window sticker?
I'm contemplating doing US dealer "window stickers" next. These would be significantly more expensive (and larger), though.
And, that's a lot more complicated as well! There are decent repops available on eBay [edit: for WINDSHIELD decals, not MSRP sheets] . The tricky part is making sure you are getting a period-correct item, as the [windshield] stickers changed about five times over three decades.
I have never seen a proper and appropriate window sticker reproduced by MBUSA.
What I would need to reproduce the window stickers would be photographs of a real 1992, 1993 and 1994 sticker. I have the base sticker from the time period, but it doesn't have E500E specifics. So, I would need to have them from multiple E500E years to ensure proper accuracy. To really make them accurate, I'd also need each owner to get the appropriate information as to the actual port of entry (there were multiple ports used), original selling dealer, and so forth. There is a LOT more work involved with a window sticker than with a data card, which has stock info that is lifted from the EPC.
It's likely that each window sticker would run probably in the $100+ range due to the amount of custom work involved, and I don't know if most owners are "down" with getting the information I'd need to create a truly accurate sticker.
I'm not worried about copyright issues on a throwaway MB window sticker for a car that is 25 years old.
My research this morning (posted in this thread) shows that MB used the same format of dealer window sticker through model year 1995, so it is a single form that covers all of the years of the E500E, as well as the late W/C126. This means that after I do a full scan of my window sticker, I can spend some time cleaning it up and creating the first draft "mockup" of it.
What I need from folks here, is an actual photograph of a 1992/1993/1994 dealer window sticker, if you possess such. I am sure that a number of you have them; I would appreciate a cell phone photo (close up) of your complete sticker so I can match the text appropriately to my scan. I also need to carefully match and balance the color scheme as part of the initial "clean-up"/mock-up process. If you can take a photo of your window sticker for me, please e-mail your photo to me at gerry@vanzandt.us
Then I can begin to offer this as a service.
Some further research also shows that MBUSA in some cases can provide copies of original window stickers, and in other cases cannot -- or will not. It is inconsistent. However, it appears that MBUSA DOES have copies in their archives of each car's dealer window sticker. Approximately 20 years ago, I was able to contact MBUSA to obtain a photocopy of the original window sticker for my 1969 300SEL 6.3.
Another avenue could be to go to the originating stealership where one's car was sold, if known. It is likely that they also have copies/records of window stickers for particular sold cars.
I was curious to see if you had made any progress on the reproduction window sticker idea?
Yes I have ... but I am not quite ready to unveil yet. Soon. The wait will be worth it.
If anyone knows of a lower-cost source for the USA window/Monroney stickers, please let us know!
I'm 2/3 of the way through my Monroney project, but haven't devoted any time to it for months.
Umm.....at the risk of being perceived as slightly rude ..... NOW AVAILABLE: Reproduction factory data cards | Factory Literature and BrochuresHi @gerryvz , any news on this cool project?
Umm.....at the risk of being perceived as slightly rude ..... how would JwashE know to look for a post about Monroney window stickers, in a thread titled Reproduction Data Cards?Umm.....at the risk of being perceived as slightly rude ..... NOW AVAILABLE: Reproduction factory data cards | Factory Literature and Brochures
...and still titled "NOW AVAILABLE: Reproduction factory data cards", followed by a bunch of irrelevant threads. I'd cut Jwash some slack, but that's just me.Well ..... it does seem to be in THREE of the first five search results.
Again, ZERO issue if someone does a search and can't find what they are looking for.TOTALLY agree about lack of searching,
Hello Guest !
We wanted to let you know about a new resource that is now available to all 500Eboard members. This is a comprehensive database of all US-market (and soon to include Canadian-market) 500E and E500 models delivered for the 1992 through 1994 model years.
Data for this resource has been compiled continuously since mid-2003, and much of this information is seeing the light of day for the very first time ever. This new resource will allow you to utilize 500Eboard research and resources to track specific cars, their sale history, documented modifications, and other information that has surfaced over the years.
We are also providing analytics about the cars' production. This means that if you are curious as to how many "Signal Red" cars were produced for the US market with a black interior, specifically in Model Year 1993, you can now easily find this information. You can also find aggregated information -- for example, how many "Black Pearl" cars were imported into the US over the three-year span.
You can always find and enjoy this resource by clicking here (bookmark the site for easy reference!), or by going to the “500Eboard Registry and VIN Database” sub-forum below. You can also find a VIN Database button at the top of your screen, for easy access.
We hope you enjoy this resource. A LOT of blood, sweat and tears over nearly 23 years have gone into its creation.
