Hello gorgeous!
VIN: WDBEA36E6NB761844
Build Date: April 1992
Mileage: 73,397
UPDATE: 28 June 2020
So sometimes life gets in the way. I've had this car for 10 months and I just have not had the time to focus on it. Lots of other projects as I know you all can appreciate. This weekend I finally got some time set aside to work on the car. So I thought that I would make this owner thread a little different in that I will manage a list of all of the items I want to do with this example and then, as I complete them, edit this entry and link to the post which shows the work I have done. Some things will be small while others will be bigger.
Engine & Transmission:
Mileage: 73,397
- Replace air tubes (See post #26)
- Replace coolant reservoir & sensor (See post #26)
- Replace hose to coolant overflow reservoir (because of post #26)
- Replace aluminum fuses
- Replace oil cap (See post #26)
- Replace insulators, rotors and caps
- Replace radiator grill and chrome strips (See post #26)
- Replace spark plugs @ 75K
- Complete transmission flush, new filter, and gasket @ 75K
- Change oil and filter @ 75K
- Change power steering fluid and filter
- Replace low pressure supply line to power steering pump
- Change fuel filter
- Replace the winshield fluid reservoir
- Install updated LCAs
- Install SA calipers and rotors
- Install steering damper
- Install new tie rods
- Install new drag link
- Replace SLS accumulators
- Replace SLS reservoir
- Install Limited springs
- Shampoo carpet and mats
- Install Limited stainless steel door sills
- Install pull switches in doors
- Install new headliner
- Install MB OEM autodimming rearview mirror
- Replace door strikers
- Replace current gear shift with V8 gear shift
- Refinish wood @ Madera Concepts
- Replace accelerator, brake, and emergency pedal pads with sport pads
- Service rear sunshade with Teflon
- Replace third brake light (See post #27)
- Update map pockets
- Reinstall factory radio (Remove Kenwood SiriusXM aftermarket head unit)
- Treat seats with Leatherique
- Service First Aid kit
- Repaint instrument cluster needles
- Replace gear shift bulb with LED
- Replace ashtray bulb with LED
- Replace instrument cluster bulbs with LEDs (white, red, blue, amber}
- Replace headlight switch panel and knob bulbs with LED
- Replace overhead seatbelt bulbs with LED
- Replace climate control bulbs with LEDs (SRS will need a capacitor)
- Replace puddle lights with LEDs
- Replace rear reading lights with LEDs
- Replace vanity mirrors with LEDs
- Replace rear seat illumination with LED
- Replace trunk illumination with LED
- Replace 3rd brake light with LED (See post #27)
- Install EVOs
- Install front license plate delete
- Paint correct body
- Repaint bumpers
- Replace the windshield wiper blade with a 124/202 OEM blade (See post #26)
- Service the wiper motor
- Replace the wiper arm cover
- Remove roof rails and have them either anodized or covered with black matte vinyl wrap
- Vinyl wrap the front and rear windshield border
- Vinyl wrap the rear passenger door window leading edge border
- Replace side mirror boots
- Replace driver's mirror with convex mirror
- Replace NAM lights with Euros
- Wire fogs to Euro lights
- Service sunroof
- Service antenna
- Replace trunk liner
- Install emergency triangle
- Install W220 bucket & tool kit (add compressor)
- Replace trunk stops
