Re: Fs: 1992 500E, Pearl Black/Gray, 154kmi, $5k (Aubrey, TX)
I first had record of this car in my database from September, 2004, when the car was located in Arlington, TX and was up for sale on eBay. At that time, the car had 134,300 miles on the odometer.
An update to the record from April, 2007, shows the following personal comments. At the time, the car was located in Aubrey, TX.
UPDATE 4-7-07: Car on eBay, seller description: it has a brand new not rebuilt 4matic transmission, it was replaced 3 yrs ago, along with timing belt. Last summer thermostat and oil bridge replaced. Ive owned car approx. 4yrs. Car is running good and is very dependable but does have some minor issues. First radio antenna doesnt go up and down all the way, slightly bent maybe the reason AM radio signal doesnt come in. FM works fine as does 6 disc cd changer,(mounted in trunk). Rear drivers side door won'tt automatically lock or unlock with key as it should, you have to manually pull up knob on door to unlock. No issues of the interior i can think of ,maybe slightly more wear of drivers side than passengers seats. Both heated seats work and has a nice Alpine stereo system. Non smoking household. Tires are fairly new with good rubber still. The exterior paint has a few small nics along the bottom sides nothing drastic there except for the top of the trunk lid where paint has started to fade/oxidize from the evening sun shining under carport, a sign the car has definetly been stored in the carport too long. Also: front shock on drivers side squeaks now, wasnt squeaking when car was stored so maybe it will stop after its driven for awhile, but it is rather annoying so it probably needs replacing. Also the AC works but not on high fan, it used to work so not sure whats wrong with that.
Further comments indicate the following:
Car located now in Aubrey, TX. Car shows aftermarket wood shift knob, aftermarket stereo, weird sticker on pass. Side airbag cover, looks like non-retracting antenna. General scuffs on front spoiler etc. Mileage 152,726
