so i have a 2003 E500 non-4matic, and i have a starting problem. the fuel pump and fuel sending unit has been replace. i verified that the fuel sing unit does deliver fuel from it spout. the fuel pump 20 amp fuel and fuel pump replay has been replaced. The fuel pump primes when in key is turned. car with start after a few cycles run ruff for a few seconds then dies.
The mass air flow sensor is replaced, all 16 spark plug. crank shaft position sensor. fuel tank pressure sensor. locking at the fuel rail when i test to see if there is any pressure fuel come out, i let it fun out the light cycle the keys and more fuel come out, but just fours out and does not quirt like if there not pressure
I dont know when else to go to get it started?
