Also be very, very careful not to disengage the throttle return spring from the other end. It's hooked on a cast tab underneath the intake manifold in the area behind the thermostat housing. I had one get unhooked on a W140 and ended up fashioning a hook out of copper wire that I wrapped around the thermostat housing to anchor it (yes, a real kludge, but I had to get the car on the road at the time!)
I ended up having to use an endoscope to see where the tab was located and with a helper, some very long hemostats and a lot of cursing, got it hooked back in place. It was not a pleasant experience.
And for what it's worth, I can't count the number of times I've bolted up an ETA only to find that the throttle linkage was below it in the "V" and unretrievable without removing the ETA again. Fortunately, I've now learned my lesson and always check this before installing an ETA.
Dan
