Well, the car showed up this morning via Reliable Carriers. The driver was a bit early, and he had it unloaded before I showed up. Upon viewing it for the first time, I am pleased to say it is even better that I hoped. Clearly it's been garaged all its life. The paint is essentially unblemished, with no paint swirl marks, and the anodized trim is perfect. There's minimal scuffing at the both corners of the front air dam, but that's about it. There's light wear on the driver's seat, the other three seats look unused. The factory's protective stick-on plastic wrap is still attached to the door sills. The radio has been replaced, but the old one was supplied.
I reviewed the dealer's service book, and pile of maintenance receipts that came with the car. Main takeaways: oil was changed religiously. Power steering pump, cooling system, window regulators, brake fluid flush, differential seals have seen work. The owner was meticulous about chasing down any leaks, from valve cover gasket to rear main seal. Something north of $30,000 in maintenance expended, most of that in the last 10 years.
I was delighted to find the original sales document from Keenan Motors in Doylestown, PA. Out the door price of $93,483, base of $84,150, with $5,415 in luxury tax, and $3,849 in sales tax. The purchaser, clearly a man of means and taste, received a $20,000 trade-in credit on his 1985 380 SE. The only options were "mats" and "stripes". The car has red over grey pin stripes, a common dealer add-on in its day. No paperwork on the Lorinser spoiler, which the Seller's son said also came from the dealer way back when.
First order of business was to check the upper harness. It was hard to read the label, even with a mirror, but I'mm 99% certain its original, and therefore, in need of immediate replacement.
Even with its (good?) maintenance history and careful ownership, I've budgeted $8-10K to sort it out. $3K of that has already been spent on the EVO's and the wiring harnesses.
To ameliorate the pain, I took her for a spin. Even without license plates, 100 mph is readily available. Drives solid and planted. "No unusual noises". A/C blows nice and cold. Seats are fantastic. I did not turn on the radio...
