ADMIN EDIT: Final solution, after 1 full year of troubleshooting and replacing parts, was a defective crank sensor. The faulty CKP (crank sensor at rear of engine) was the root cause of the lambda (on/off ratio) malfunction and incorrect mixture. See post #76-#81 (link) for details.
The title says it all. I've had this problem for a while - idle is uneven - engine is shaking a bit, it almost feels like it's missing, at certain throttle positions the car hesitates when accelerating, and - at least I feel - the car should be quicker. A friend owning a w124 E36 says the same.
The car in question is a 1993 500E, 171k miles.
What I have done:
Replaced S29/3 Idle switch at accelerator pedal (Mercedes)
Replaced S16/1 Neutral Safety Switch (Mercedes)
Replaced Brake Lamp Switch (Mercedes)
Replaced vacuum seals between lower and upper intake (Mercedes)
Replaced rubber between ETA and MAF (Mercedes)
Replaced a few vacuum hoses here and there, checked the entire vacuum system in the engine compartment
Replaced gasket between intake and ETA (Mercedes)
Replaced intake gaskets (Mercedes)
Replaced distributor rotors (Bosch)
Replaced distributor caps (Bosch)
Replaced distributor dust covers (Bosch)
Replaced spark plugs (Mercedes) - they are the correct for the car (Bosch F8DC4)
Replaced spark plug wires and coil wires (Bosch)
Replaced the oxygen sensor (Mercedes)
Replaced air filters (Mercedes)
Replaced ignition coils (Bosch)
Replaced catalytic converters (brand new from a company in Germany)
Replaced LH-module with an early one with WOT
Replaced fuel pressure regulator (Genuine Bosch)
Replaced intake air sensor (Mercedes)
Replaced MAF (used refurbished Bosch-unit. Original MAF was dirty/oily.)
I checked the MAF with STAR C3: Values are 1,50V and 21,8 kg/h at idle. Voltage rose to 2,0-2,1 at 3000 rpm.
I have checked the fuel pressure; it's 3,65 bar with vacuum @ idle, rising for a second if I press the accelerator and then going back to about 3,65 bar (with vacuum).
After shutting the engine off it stays at 3,65 bar for at least one hour (that's when I disconnected the metering device).
What I have not done/ought to be investigated:
Smoked the vacuum system
Tested the EZL
As far as I know I don't have any fault codes now.
What else haven't I checked? Where do I go from here?
What I have done:
Tested the EZL
