WANTED Used Engine-Bay Fuel Hoses from 400E / E420 / 500E / E500
Jlaa
OG ⏰ 500E
Hello,
I would like to buy these two fuel hoses (used) from the aforementioned cars. If you have a parts car or have these from a junkyard, may I purchase it? Thanks.
124-470-50-64
124-470-53-64
The diagram shows below where these hoses are located in the car. Thank you.
@Jlaa, FYI, these are long assemblies of pipe + hose. And, there are 2 different lengths, I think from early vs late build (not sure if break point is the same between 034/036). Assuming you want identical items, you may need to measure your existing ones for comparison.
The difference should only be below the bottom firewall clamp with the offset plastic "screw". I believe above that clamp they are all the same. I vaguely recall the 034 and/or late 036 having longer metal pipes, extending further down? First 2 pics below are from a 1993 500E (may be identical to yours), last pic is from a late 034 (E420).
Thanks @gsxr! The difference in length doesn’t bother me. I would like to experiment with the possibility of rebuilding/remanning these without taking the existing hoses off my car yet!
