Hi All,
I am having issues with Xentry/DAS. I have a C4Plus DOIP Multiplexer. 2015 Xentry. Dell Laptop. The setup worked fine with my 2015 ML250 CDI, but runs into issues with my older 2005 E500. I'm guessing some issue with DAS and the multiplexer. My current thought is that the 2005 vehicle isn't compatible with the C4 OBD2 DOIP cable, and that maybe it will work with a standard OBD to C4 cable. Does that make sense?
Error message I get is as below:
Fault (1.18)-890
Communication Fault
Incorrect vehicle connection cable used between diagnosis multiplexer and vehicle diagnostics socket
Diagnostics data sectors missing or incomplete.
Thanks,
Max
Fault (1.18)-890
Communication Fault
Thanks,
Max
