Wheel alignment specs
cossie
I just replaced the front struts and the 5 rear control arm links. I don't know if the new struts affect alignment but it now slightly swerves to the left. While the rear has noticable toe in (more on the right) and negative camber. The rear camber has been that way prior to replacement which I thought new camber links can somehow correct. The car by the way has stock springs and pads, hence the normal height.
Anyway, it definitely needs a wheel alignment to address the issues. Having said this, can anyone please share the factory or recommended front and rear alignment values.
Thanks in advance.
See attached. Remember that rear camber is not adjustable, unless you buy a camber correction kit (i.e., Megan Racing camber arms).
:mushroom1:
