Anyone try this?
http://www.hidxenonheadlights.com/
If the bulb connector is stock, it's just a plain halogen bulb. Any HID conversion will have modified wiring with external ballasts (metal box roughly the size of a cigarette pack). Tinted blue bulbs are strictly for looks, they actually reduce light output in lumens. Best thing to do is pull the bulb out and read what it says. Here's a close-up of the Osram 70/65 and 85/80:Is there a way to tell if the lights currently installed are xenon, hid, or just a different color bulb?
"This might be interessting aswell...
http://www.ridethatbike.com/NOMAD orginal/HEADLIGHT.htm
A shame i can not get these Osram Plus 50 (with 70/65 or 85/80) in germany anywhere....
I use now Osram Nightbreaker H4 here in our cars, before we had the H4 Power2Night GT150+ in my cars, which are both a HUGE difference over stock bulbs. Power Rating is same as stock, however light is brighter, light-color (Kelvin) is higher and more "white" than "yellow".
The have the same wattage than any other in Germany allowed "stock" H4 Bulbs."
Christian, what's the wattage on these Osram Nightbreakers and how long do they last versus stock 60/55?? No issues on "bulb failure" warning light coming on?
SilverStartStar anything = blah, blah, blah. All these "plus 50" bulbs are still 60/55 watts and can't put out the lumens you'll get from a higher wattage bulb. Color temp (blue or otherwise) is strictly a cosmetic thing, it DOES NOT help you see any better.
The Osram 70/65 are still going to give you the most light (lumens) possible using stock wiring and halogen bulbs.
I think that's too high of a wattage to be using on stock wiring without relays, for safety's sake.I had higher wattage (90w) on the 500E for years with no issue.
The cutting into the factory wiring is relatively simple, and could be un-done in the future if desired. All the work is done at the headlight connectors themselves. See attached photos. It's a LOT of work, but the parts aren't that expensive. My install was a bit overkill on the wire size. Use separate fuses for left & right so if one fuse blows, you don't lose both lights.Any way to install relays without cutting into factory wiring? Can a simple adapter be made up?
A PIAA is very effective straight bulbs H4 & H7 any comentsAll that "hi tech" lighting is unnecessary. I can't stand when someone passes me with aftermarket junk blasting my eyes. I have Hella euros with Osram 70/65w H4's and they are plenty good. Bright, clear and focused. If you absolutely must have more output then install relays and higher wattage bulbs. gsxrs link points to Daniel Stern, an authority in vehicle lighting. I tend to listen to what he says.
Rik,
Have you tried HiR yet? Looks promissing...
