Like I said, you need an expert mechanic to help you assess the condition of things and ensure that the car is "up to date" with regard to key service items and fluids. Your list in the immediately preceding post looks prudent and appropriate as compared to what you were proposing in your first message and in the "doomsday scenario" responses from other board members.
Realistically, the
upper wiring harness should be proactively replaced, though on a car with 60K miles it very likely hasn't seen a lot of heat damage nor has it been rooted around (moved) by a mechanic doing other top-of-the-engine work. So yes it should be replaced, but IMHO it's not an IMMEDIATE "must-do" item. Now if your car had 150-200k miles on it, then I'd be saying that it should be the FIRST thing you should do.
If your upper and lower radiator hoses and serpentine belt haven't been replaced that you know of, then I would replace those out of hand. I've seen serpentine belts with significant cracks even after just a couple or three years. If you live in a hot climate, it's even more critical as the rubber breaks down even faster (I recently experienced an alternator belt failure of a Conti belt on my 560SEC after less than 1.5 years no the car). I agree that is cheap insurance and important for baselining a car. Thermostat too.
But for some of these other things, you really only need to replace them if they are going bad, and generally if you are in tune with your car you will know they are going bad. i.e. the fuel pumps -- generally you can HEAR them going bad before they fail. And it would be unlikely for fuel pumps to fail before 100-125K miles. So you have plenty of life in them.
Fan clutch? it's documented here how to check if it's bad or not. You'll also be able to tell pretty easily depending on the temps your car reaches on hot summer days or at high speeds under load. Not necessary to replace unless bad/failed. Not saying yours isn't, but you should check it & confirm it's bad before just throwing a new part on the car.
A radiator IMHO is not required for proactive replacement on a 60K car unless it is leaking or if it sat around with the wrong (non-MB or Zerex) coolant in the engine.
Same thing for a water pump. Generally water pumps leak slightly out the weep-hole, which is a visual indicator of its internal condition. Not weeping/leaking .... no worries. Not gonna leave you stranded by the side of the road, generally.
Cam solenoids/magnets on a 60K car? Not likely a problem. A knowledgeable mechanic can help out with diagnosing this, but IMHO it's not a widespread issue that requires proactive replacement/maintenance.
Thermostat in the washer bottle would only be required for replacement if you can see that it has failed by checking the reservoir. I mean seriously, I've never seen this as an issue among the hundreds of folks I've known, over the past 9 years. Yes it's a cheap part and easy to fix, but is it going to leave you stranded by the side of the road? Probably not.
The neutral safety switch. Just not going to fail on a 60K car. I've replaced them on my E320 wagon and my E500 and it's a part that generally fails with usage -- it's a combination mechanical + electrical part. Again, generally you have plenty of warning that it's failing. If your car had 125K miles on it, then it might be a candidate for replacement. Otherwise, it's just not necessary on a 60K car.
Caps and rotors -- definitely inspect them. Replace depending on condition. If corroded with nasty green stuff or carbon tracking inside the caps, and pitted-out cap contacts and rotors, definitely replace. If they're clean, just clean them up a bit more and be on your way. Plugs -- every 20-30K should be fine. Inspect and replace if necessary. Or re-gap yours if they check out OK.
Fuel filter -- replace every 20-30K miles. If you are baselining the car, then I agree it's a good idea to replace it.
Cabin filters -- a "nice to do" item that most owners here have never even done!! Gonna leave you stranded by the side of the road? Nope. Heck, 1992 and 1993 cars don't even have 'em !!
I've yet to see an E500E that DIDN'T need at least $2K in repairs/maintenance. Usually it's around $5K no matter what anyone here says. With your car, I'd be most concerned with the rubber bits due to age and non-use -- suspension bushings, motor mounts, hoses, shift linkage bushings, steering shock, drag link, and so forth.
But like I originally said, get a mechanic to test and assess everything, and then you can build your "to do" list based on what he finds. Outside of a couple of items like the wiring harness, gobs of "proactive" maintenance just isn't necessary on these cars.
I'm surprised nobody mentioned the evaporator and the climate control vacuum pods, speaking of proactive maintenance. Evaporators & vac pods are like wiring harnesses - all of them go bad sooner or later. And the labor in replacing all of that will run you an easy $2,500 right there. Just sayin'. Not gonna leave you stranded by the side of the road -- just uncomfortably hot.
Power steering/tandem pump is another problem area, but you will know either by seeing seepage UNDER the car or inspecting the level of the steering fluid as to whether you have a problem there or not. Lots of owners have tandem pump and/or steering gearbox issues. $$$, but only if needed. Not gonna leave you stranded by the side of the road.
