Nevermind. On further research, it looks like the inside of the alternator shaft is a 12-spline 10mm flange -- not a Torx which is only 6-spline.  Mac tools makes one (SC90 10mm).  I just bought one on Ebay for $25.
12-spline flange
The
12-spline flange screw drive has twelve
splines in the fastener and tool. It consists of 12 equally spaced protrusions, each with a 60° angle. It is achieved overlaying 4 equilateral triangles, each one rotated 30° over the previous one. The spline drive was part of the obsolete, U.S-designed
Optimum Metric Fastener System and was defined by
ASTM B18.2.7.1M, which was withdrawn in 2011,
[70] making the spline drive obsolescent. Spline drives were specified for 5, 6.3, 8, 10, 12, 14, 16, and 20 mm size screws.
[71] Its primary advantage is its ability to resist
cam out, so it is used in high-torque applications, such as
tamper-proof lug nuts, cylinder head bolts, and other engine bolts.
