I didnt see on the pictures any flaws
Go for it Arkady- it is very likely I know about them already anyway.I do 2 major one, but i don´t want to destroy good mood of TimL![]()
Interesting... can you capture the imperfections on camera ? What other options do we have in USA for restoration, now that most all the wood is NLA?It for sure looks much nicer than before, but it ain’t perfect and I don’t think I would go back to Madera if I ever have other wood trim in need of restoration.
The shifter board cracks didn’t get fixed properly. Look at the long black line that starts below the hole of the fader and goes all the way to the end of the board...........disappointing.Interesting... can you capture the imperfections on camera ? What other options do we have in USA for restoration, now that most all the wood is NLA?
They told me initially that they offer re-veneering if needed. The cracks in the rear center console were much worse and that piece turned out perfectly, so I’m a bit surprised they didn’t properly fix the shifter board.Ah, now I see it! If the crack is in the veneer, I don't know if it's fixable... but I'm not a wood expert. @LWB250 ?
Maybe I’m nitpicking, but at a price of $1k for six pieces I’d have expected all cracks to be fixedI'm really surprised that Madera didn't re-veneer the piece. I would have thought they'd have done that with a crack in the veneer itself. This is the very first I've heard of disappointment in Madera since I first became aware of them 20 years ago.
Yeah totally - pls call them @TimL . Also, is it all Manny now or is Jeff Wayco still involved? Jeff would never have allowed that piece to pass quality control.Honestly, Tim, I would call them, and send the piece(s) back to them for a re-do. I am sure they will stand behind their work if you discuss with them why you are not happy and what specifically is not right.
You might be right, Gerry. I think I will give them a call on Monday to discuss and see what their thoughts are. It somehow doesn’t seem quite right to still have a visible line where the crack used to be and once you know where it is it’s difficult to unsee.Honestly, Tim, I would call them, and send the piece(s) back to them for a re-do. I am sure they will stand behind their work if you discuss with them why you are not happy and what specifically is not right.
I only dealt with Manny throughout the process.Yeah totally - pls call them @TimL . Also, is it all Manny now or is Jeff Wayco still involved? Jeff would never have allowed that piece to pass quality control.
Sure you do.Go for it Arkady- it is very likely I know about them already anyway.
Sure you do.
I made same mistake, i didn´t change the wooden trim completely, and had same result- all corners are not sharp anymore ( button wholes) and wooden part of the small box is very uneven, cause it has to be cafrefully polished. It has to fit each other much closer, hope you know what i mean.
Example pic, sorry for zebrano.
So @LWB250, you are saying there is no way the visible line from what used to be a crack is fixable? Would love to get your opinion before deciding if I reach out to them or not.Nope. That and it will show up in the finish as well, most likely.
-D
Thanks Dan, appreciate the info. I’m not worried about the stowage box piece, as I think that looks just fine. It’s the shifter panel that I’m not 100% happy with, so I guess I will reach out to Madera tomorrow and see what they think. If it can’t be done then I’ll just take it as it is. It’s maybe a bit of a nitpick anyway....Tough to say without seeing it. In many cases, much depending on the type of finish and how it's applied, a crack or defect in the wood's surface will manifest itself in the finish, too.
As for the rounded edges on the tambour for the center console, I never figured out how Mercedes did that. I figured they finished the piece first, then used some sort of a saw or cutter to cut the pieces into strips. I don't know how else you could get an edge like that. If I recall the sides of the pieces are painted black, so it would be easy to take a piece the size of the tambour strips and with a very sharp edge (guillotine) cutter or blade cut it up into strips. After doing so you paint the edges then glue it onto the fabric to make the tambour.
I wish Drew Tibcken was still with us - he would know it was done.
-D
I know what you mean. Driving this car imparts an immensely satisfying sense of operating fine machinery. It goes down the road in an extraordinarily regal manner that is lost on more modern cars ..... and yet it moves with equal alacrity as the modern stuff.Some very decent fall weather today, so I went for a lazy Sunday morning drive, grabbed a coffee at Pike Place and took a few pictures while out.
I just love driving this car.....maybe a little too much. Bought the car when it had 87k miles in June of 2018 and just past the 100k mile mark today
Enjoyed every single mile though and am looking forward to many more
Yesterday the weather was decent, so I decided to put the RIALs back on and to go for drive afterwards to grab an outdoor, socially distanced, beer, staring at my parked car and pondering that while I had a bunch of things fixed the last two years, there still remain a lot of items I’d like to get done. I’s a bit of a never ending story, but I enjoy the car, so I want to keep at it to get it to as proper a level as I can.
Next up are the following items:
-Install new blower motor (current motor squeaks)
- install new wiper motor (while in there)
- Install new wiper gears (while in there)
- install new washer reservoir and associated components
- install new hydraulic suspension reservoir
I have all the parts already, so now it’s just a matter of getting time with Steve Geyer in January.
It’s definitely slow going, but it is what it is.
Thanks for the advice Jlaa! I will buy a regulator then to go in at the same time. Actually, your educational blower motor videos and hints helped me source an OEM/Bosch motor from the same source that you had purchased yours from a while agoIf you are installing a new blower motor, please
do not forget to change the regulator (transistor) at the same time! You don’t want to go back in there twice.
For the regulator, For my tastes I stay with MB or OEM. In my owners thread, I noted that I lucked out and found that the ACM I bought was a repackaged OE MB/Bosch regulator with the star scratched off.
For the blower assembly, also only buy MB or OEM Behr or “aftermarket” Behr/Hella Service.
BTW if I can change the blower motor, ANYONE can.![]()
The wiper electrical motor is a pretty rare failure, or at least I can't recall the last time someone had a bad one. The mechanism usually needs lubrication internally to speed things up, which is not easy as the gear mechanism cannot be easily disassembled. If Steve is doing the work, you'll be fine, but I'd consider it a semi-advanced DIY. Late style wipers (all but earliest facelift) are a different design and you can just pop the plastic cover off and lube everything. Can't do that on the early version with metal cover.- install new wiper motor (while in there)
Thank you, Jon- I feel similarlyInteresting change Tim. I must say, I think I am partial to the Rials!
overall still looksAs usual!
Thank you for the heads up Dave! Yes, you had mentioned the washer reservoir in an earlier post (#78), so I will ask Steve to modify the bracket. The headlight adjustment might be the straw that breaks the camel's back!Nice list, Tim! A few comments:
1) The new washer reservoir has the base shaped differently, and will sit ~1/2" higher than normal, which means the back flange bends when you tighten it down. Search the forum for details. You either live with it not seating properly, or modify the metal bracket on the body to adjust for the difference.
2) The seat belt buzzer can be defeated by separating a 2-pole connector below the driver seat, near the front. I do this on all of my 124's.
3) The headlights will probably require re-alignment after installing the vacuum level adjust.
On the inside
- Install used (but decent condition) ROW lower dashboard cover (the one without North American market bulge)
- De-install that infernal North American seat belt buzzer
It's easy. There are only 2 wires with a small 2-pole connector under the front seat. One has a bright red connecting housing - DO NOT disconnect this, it's for the SRS/airbag system.What? Really? Do you have pics on w124perf anywhere on which 2-pole connector this is? I HATE the seatbelt buzzer.
Driver seat only, AFAIK... don't think the passenger seat triggers the buzzer.Unplug the black plug under driver’s seat only or both seats?
I’ll do it this morningDriver seat only, AFAIK... don't think the passenger seat triggers the buzzer.
If anyone does this, maybe try to snap a photo of the offending connector + location, we can create a new thread with the info...
Good to see that there seem to be more people who strongly dislike this North American "safety feature"I’ll do it this morning![]()
Thank you Merlin! Fingers crossed it actually all now happens and Steve has some time for this laundry list soonWow Tim,
very nice work and lovely attention to the details!
Yup! Unplug that and see what happens.@gsxr --- is it this one? This is looking from the the rear of the seat. This connector has GRN + GRN-BLK on one site and BLU-BRN on the other side?
Awesome thank you! There are three "infernal-buzzer" modes that I am familiar with:Yup! Unplug that and see what happens.
Yes, GraySwitch™ works as a workaround for this. I keep wondering when my GraySwitch™ will wear out cuz I've used it so much.
- Key OFF, Door OPEN, Lights ON --> BUZZ --> You probably want this reminder, but the GraySwitch uprgade may help?
- Key ACC, Door OPEN --> BUZZ --> The GraySwitch™ upgrade cures this scenario.
- Key ON, Door CLOSED --> BUZZ ---> Unplugging the black two-wire connectors address this scenario.
I can't recall if the same buzzer is used for all three. I personally want the lights-on reminder, and don't mind the key-left-on reminder (since I can disable with the switch, if needed). The third one had the highest fingernails-on-chalkboard quotient for me.
