I would rather hold the balancer. The bolt is super tight and holding the flex plate doesn’t appeal to me. All. that torque on a couple of teeth.Do you mean the holding tool for the flex plate, which locks the crankshaft so you can remove the 27mm hex crank bolt? That is tool # 601-589-02-40-00, same as the M103.
Are you using the procedure in the factory manual?
Zero issues with locking the flex disc. (Unless a ham fisted type uses a screwdriver or inappropriate method of course anything is possible!)Any concern of ring gear damage? Why the change for the later models? I would rather damage the balancer than have a issue with the flex plate. Had anyone had issues with damaged flex plates?
I appreciate the info on the factory procedure that was written 25year + ago.
Thanks for the info. I would love to use a impact but even with the radiator removed not enough room for my trusty CP 734.Zero issues with locking the flex disc. (Unless a ham fisted type uses a screwdriver or inappropriate method of course anything is possible!)
Personally I use a powerful impact gun where possible to loosen MB crank bolts. Where not possible use a crank lock tool, slide it in place at starter motor etc and use a large bar to break the crank bolt.
Thanks for the input. With the engine lifted from the pan with a 2x6 to spread out the stress, to the point that it seams to hit the firewall, there is no way there is clearance enough for the pan to clear the crossmember!! Don’t want to brake anything. Kinda hard to use the lifting lug with the timing cover off.I am not aware of anyone here who has removed the lower cover on an M104, at least recently. But there is (as your post infers) a lot of danger in damaging the pan gasket. My recommendation is to remove the oil pan so that you don't mess anything up.
There is, as said, ZERO issue with using the factory tool to hold the ring gear. As long as it is inserted correctly and getting a proper "bite" on the ring gear teeth, everything should be just fine. I just did this last year on my M119 when removing the crank bolt/pulley/harmonic balancer so that I could replace the front crank seal, using a quality aftermarket reproduction of the factory tool.
On our daily driver which sees the most use, I do go 10k with Red Line, plus oil analysis with TBN. Results show this is about the limit over an 18-30 month period with no oil consumed or added, as the TBN is near the minimum. If adding some oil due to consumption, this can actually extend the interval, as the make-up oil will boost TBN. I don't recommend extended drains without at least a couple of analyses with TBN to verify the interval is safe for that particular engine and OCI.But I know that the @gsxr goes 10K with his RedLine, and that works well for him !
I removed the crank bolt by having a friend just blip the starter while tightly holding the crank bolt with a three foot “cheater bar“ on a 1/2 inch break over bar. Not sure how I will tighten it back, but I’m a long way from that now.I would rather hold the balancer. The bolt is super tight and holding the flex plate doesn’t appeal to me. All. that torque on a couple of teeth.
I did my Acura timing belt and the bolt had major locktite on it.
They make tools for this for other newer Benz and that seams to me to be the way to go.
Here's what I did last year with my M119.I removed the crank bolt by having a friend just blip the starter while tightly holding the crank bolt with a three foot “cheater bar“ on a 1/2 inch break over bar. Not sure how I will tighten it back, but I’m a long way from that now.
Something similar on my m119- I have a huge 3/4 torque wrench reserved for crank boltsHere's what I did last year with my M119.
Please tell me more about the center bolt re-torque. What’s the best practice here? I couldn’t find any information in Gerry’s “How To”.Zero concern of ring gear damage for engines designed to use the lock tool on the flex plate / ring gear. There is minimal load at the teeth due to the distance between crank centerline and the teeth. The balancer has a rubber element and is not designed to take those loads. I've never heard of flex plate damage when using the factory tools, ever. Now if someone is using "creative" methods to hold the flex plate, that's a different question... be careful if not using the proper tools.
A beefy impact wrench usually makes removal a breeze, but the bigger hassle is getting the center bolt re-torqued to spec, either 370Nm or 400Nm, depending which type is on your car. Need a large 3/4" torque wrench, and if renting one, hope that it's properly calibrated.
I actually found an article where Gerry used a 1.75” diameter pipe over his torque wrench.Assuming you are replacing the front crank seal and need to tighten the 27mm bolt afterwards: This requires using a flywheel lock (or other positive-locking methods on the flywheel), and using a large torque wrench capable of rated spec.
M104 flywheel lock:
M104 torque info:
I agree on the lack of calibration data wirh rental torque wrenches, and that’s why I buy my own. I own a Craftsman (1/2” drive) which is many years old but max torque is 250ftlbs, and it’s my old reliable for smaller jobs.3/4" torque wrenches are crazy expensive to purchase. There are torque multipliers, but those aren't cheap either. I wonder if an extension (from wrench to socket) might work.
You can rent a 3/4" torque wrench, but I'd be nervous unless the rental place confirms that they calibrate them regularly, AND it's not a cheap wrench to start with. I vaguely recall hearing of rental places offering a beat-up Pittsburgh with no calibration data. I'd rather buy a new one that I know hasn't been abused (yet).
The cheater pipe is to make it easier to pull. 400Nm takes a lot of muscle, it's difficult for the non-bodybuilding crowd (like me).
Nice humor.I think the Tekton is the one I got at Home Depot.
TEKTON 3/4 in. Drive Click Torque Wrench (50-300 ft./lb.) 24350 - The Home Depot
Bring a powerful torque on tough jobs using TEKTON Drive Click Torque Wrench. Ensures good quality and durability for longer life.www.homedepot.com
It's not awesome quality, but it's totally functional, accurate enough, and worked well. Worth the $75.
More importantly, the chicks will totally dig the beefiness of this tool, and watching you use it.
I still have this trepidation concerning my front seal replacement. I have removed the pulley, installed my flywheel locking tool, and now I’m waiting to turn the 27 bolt. My main concern is the woodruff key, and getting the damper back in place without damaging the key. What precautions would you suggest I take?I ordered my torque wrench through Home Depot. It seemed the best option at the best price.
I will review the M119 pics.As far as I remember, the Woodruff Key fits into a groove in the crank snout and fits into a slot in the hub. You just have to roughly mark the hub and the crank snout so that you line them up when re installing, and the Woodruff key should line up just fine in the groove in the hub.
The damper just slides on and off, and there is zero contact with the Woodruff key. You need to use a puller to remove the hub from the crank. The Woodruff key should stay captive in its groove in the crank. I didn’t mess with it and it is back in there so not immediately visually apparent.
Check my photos on thr M119 because the M104 should be fairly similar.
Dave:You can't hold the balancer without damaging it, while trying to remove (and then tighten) the 27mm hub bolt. The factory procedure is to hold the flex plate - it is designed for this.
I will cautiously follow the steps.Link to the FSM procedure is below. You need a puller to pull the hub off the crank snout. Don't damage the balancer. If tight, you leave the balancer on the hub and remove both together. Don't pull on the outer edges of the balancer. A generic puller from the local McParts will work, similar to what's shown below, but you will need to remove the radiator for clearance.
Absolutely! How about the re-install. Are there any special tools/precautions so as not to dislodge the woodruff key?Again, the basic procedure is well covered in the M119 Top-End Refresh thread as for pulling the hub and balancer off. Please see this post for info.
The M104 is essentially the same design as the M119 in this regard. I used a cheap McFLAPS bought puller.
After you remove the hub+harmonic balancer combo, you should be able to remove the harmonic balancer from the hub by carefully working it back and forth with your fingers until it comes off. If I remember correctly, it's a press-fit onto the hub. You should NOT use any sort of device or puller on the harmonic balancer itself.
![[500Eboard] IMG_9074.jpeg [500Eboard] IMG_9074.jpeg](https://www.500eboard.co/forums/data/attachments/136/136517-dfbe8b11d3fe977cb5ee0a0f3d2431aa.jpg?hash=376LEdP-l3)
![[500Eboard] IMG_9076.jpeg [500Eboard] IMG_9076.jpeg](https://www.500eboard.co/forums/data/attachments/136/136518-f671317362310fc43715fdbc938505d4.jpg?hash=9nExc2IxD8)
![[500Eboard] IMG_9079.jpeg [500Eboard] IMG_9079.jpeg](https://www.500eboard.co/forums/data/attachments/136/136519-1d112971f7c4ed7df8a3f2e3684df3fd.jpg?hash=HREpcffE7X)
![[500Eboard] IMG_9547.jpeg [500Eboard] IMG_9547.jpeg](https://www.500eboard.co/forums/data/attachments/136/136521-30b28dfa72741b1c92cfc63e058607b8.jpg?hash=MLKN-nJ0Gx)
![[500Eboard] IMG_9550.jpeg [500Eboard] IMG_9550.jpeg](https://www.500eboard.co/forums/data/attachments/136/136520-3734266d9223275c586fc6bca06e88c7.jpg?hash=NzQmbZIjJ1)
![[500Eboard] IMG_9552.jpeg [500Eboard] IMG_9552.jpeg](https://www.500eboard.co/forums/data/attachments/136/136523-f74bdbe4a6a81cd37bbe85cce31bf714.jpg?hash=90vb5KaoHN)
I apologize. No more questions!I'm dreadfully sorry, but I'm getting a little frustrated. ALL of this information is found and well laid-out verbally and photographically within my Top-End Refresh thread. The procedure for the M119 and the M104 are nearly identical for this hub removal and installation. I am spending my precious morning work-time, repeating what I already posted over a year ago, which is very very apparent in the thread.
Again, if you mark both the hub and the opposite location on the aluminum casting with matching center-punch dots where the hub presses into, then it will line up perfectly and you won't have a problem with the Woodruff Key. It will remain in its slot. I showed this (marking) and (hub insertion) in my M119 Top End Refresh thread. Woodruff Key alignment was a non-issue because I marked everything, and re-installed everything according to the marks I made.
Description of hub re-installation (& woodruff key alignment) is here.
Marked hub + front cover as it came off the car:
Marked hub with center punch after removal:
Front cover marked with center punch:
Re-installing the hub by hand:
Moving the hub into final position with light taps. NOTICE the center punch marks on the hub and timing cover are ALIGNED.
View attachment 136673 View attachment 136671
Hub installed. Note that there was no Woodruff key issue, because everything was lined up the same orientation in which it was removed. Notice the two marks perfectly aligned in the photo below.
Final harmonic balancer installation is located toward the bottom of this post.
Hello Guest !
