Yes - measuring exhaust backpressure ahead of the catalysts. Either a bung has to be added, or the O2 sensor can be temporarily replaced with a an adapter fitting. Normal should be under about 3psi maximum at any RPM, at full throttle. Full load is required, can't test revving in Park (well, unless the cats are almost totally plugged, in which case the car would also be undriveable).
