Albrex supercharger kits can also still be found out of Japan by the original producer, no idea what they cost but I found the website the other day. I'll try to find the link again and post...
The Japanese site translation has some interesting info. Ported/polished with custom (all aluminium!?) cams and they are getting near 370hp from 5.0L? But only 400hp from an Albrex supercharger with stock 5.0L? At least they bump that to 430-450 with both the modifications and SC combined, but still... I was kinda expecting more with modern ECU controls.
Excerpt:
" One example is our original gold engine. ... loss in each part has been eliminated, and the flow of intake air and exhaust is smoothed with a unique cam profile, valve, valve seat processing and guide cutting (same method as AMG and Brabus). ... maximum output is 370 horsepower or more, while maintaining the displacement of 5.0L.
In Stage 1 , we will process it into a normal engine and install a Supercharger. A maximum output of 400PS is possible [from 5.0L].
In stage 2 , we will use the previous gold engine as a base and make a separate process for the Supercharger and install the supercharger. Maximum output 430PS-450PS is possible [from 5.0L].
Stage 3 is a 6.0L engine with a supercharger, capable of up to 550 horsepower.
The performance of the M119 V8 engine, which is over 200kg lighter than the M120 engine, is truly the ultimate."
I assume Stage 3 is based on a 6.0L "gold engine" to get 550hp.
Also not sure if the M120 is as porky as they claim. Internet says the complete M120 with accessories is 290kg/640lbs. Clearly, the M119 does not weigh only 90kg/200lbs so that is a typo. Found data that a loaded M117 is 235kg/515lbs, so the M119 should not be significantly heavier.
