Wiki unavailable?
JC220
I have been trying to get into the 500E Board Wiki section on & off for a few days now and keep getting a message saying "Currently closed for maintenance" or something to that effect.
Are mods aware the Wiki has been offline for some time now?
Joe
Yes I am still getting the same message - even with your link Dave
"The wiki is currently closed for maintenance. It will be available again shortly."
On a Firefox browser.
It should be active for all users now. However, there are issues with it.
The software version is woefully out of date, and I have let the license lapse some time ago, because I have not been entirely happy with the product.
However, folks should be able to get into the Wiki now.
No, it's an issue with the software, which has been quite buggy and broke all of the links with an upgrade I did some time back. Which is why I disabled the Wiki in the first place.
Wiki section has a problem, the links show a different image than the one originally linked or uploaded. Can an admin please look into this? Thanks
Do you know which wiki page? Is it the paint codes one?
I added paint/interior combos not too long ago so hopefully didn't mess anything up. I just opened up some of them and see the same ones I clicked on.
All Wikis that I've seen with links to images.
At the bottom there's a images section.
I have re-enabled the Wiki, and will be working with the developer if any errors start to show up.
:update:
Errors are showing up, but the Wiki should be perfectly usable for folks. If you are seeing any error screens, please reply to this post.
It should be working fine, but it is again starting to throw errors on the back end.
I have a fix available for the Wiki, from the developer. The problem had already been identified.
I have to modify one of the files online on the server, with a line or two of updated code.
Hoping this solves the issue.
:update:
The problem now appears to be fixed. I will keep an eye to see if any new error messages appear over the next day or so, but it appears as if all is now well.
