SOLD DAS AUTOGANZ E60 Specs Springs (BRAND NEW - CONUS)
slvrwlf
I'm selling a brand new set of DAS AUTOGANZ E60 Spec Springs.
I bought this as a spare set as I was planning on doing a full refresh of my car, but ended up selling the car. I waited close to 6 months for these springs.
I emailed Hirosawa-San prior to purchasing and he confirmed that they are exact specs. Another member on here mentioned that there are very minimal differences in spring rates however, I cannot personally confirm this, so I’ll leave it to the buyer to assess and decide.
Das Autoganz specs:
Front: 9.8kgf/mm
Rear: 8.8kgf/mm
Original MB E60 AMG specs:
Front: 10kgf/mm
Rear: 9kgf/mm
Price: $690 (Exactly what I paid in 2024) + shipping.
I want these, if , for no other reason than having the actual spring rate available for these…
H&R, I don’t think , gave away the spring rates for the 500E sls type springs.
Do you have pictures of the cars that ran these springs (is that maybe why you ordered them?)
I keep debating running a coil over type front damper with oem equivalent lowering springs as to not mess with the issue of converting to a coil over type strut on the 500E and I feel knowing what the spring rate is would help to match the front shock valving to the spring rate. But I guess I would keep the sls in the rear.. hmm
The first car with the BBS RS is running a 19in setup and the second car is 18in.
Das Autoganz specs:
Front: 9.8kgf/mm
Rear: 8.8kgf/mm
Front: 10kgf/mm
Rear: 9kgf/mm
@slvrwlf, can you specify the length on the springs please.
I measured from the flat end of the springs to the tallest point.
Rear
Front
