No affiliation. Love this color combo. This car doesn't have Sound System, however it has Jehnert doorboards! The listing does not mention this, so the seller may not know what they are. No idea what amplifier is installed or where it is located, no aftermarket amps are visible in the photos.
Located in SoCal with Montana title.
Despite the clear statement about CARB, a peanut gallerist already asked if it's passed CA smog.
CarFax report is totally useless as it only shows the registration/title in MT in Dec-2023. Amazingly, the car has correct Euro headlight lenses, although one is cracked, ouch. Seller should have taken care of the sagging headliner before listing.
VIN = WDB1240361B819337
Datacard: https://www.lastvin.com/vin/Dw1lNd5x1OJARkqy9
bringatrailer.com
Euro 1992 Mercedes-Benz 500E
Bid for the chance to own a Euro 1992 Mercedes-Benz 500E at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #189,278.
This 1992 Mercedes-Benz 500E is a Swiss-market model that was specified in Bornite Metallic over black leather and Karo cloth. It remained in Switzerland until it was purchased by the current owner and imported into the US in late-2023, and it now shows 195k kilometers (~121k miles). Power is from a 5.0-liter M119 V8 paired with a four-speed automatic transmission, and equipment includes 16″ eight-hole alloy wheels, a power sunroof, fog lights, Automatic Slip Control, automatic climate control, heated power-adjustable front seats, cruise control, and a US-spec Becker cassette radio with Bluetooth. Recent work has included replacing ignition components, the neutral safety switch, and the shifter bushings. This W124 500E is now offered on dealer consignment in California with the removed radio, a clean but completely useless Carfax report showing no accidents in the 16 months it's been in USA, and a clean Montana title.
The 500E was assembled by Porsche and featured wheel arch flares, revised bodywork, and a lower ride height when compared to other W124 models. This example was finished from the factory in Bornite Metallic (481) with lighter lower cladding, and it was repainted at some point under prior ownership.
Additional exterior features include headlight wipers, integrated fog lights, a retractable antenna, and a power sunroof. The right headlight is cracked, and paint blemishes are noted beneath the front bumper.
The 16″ eight-hole alloy wheels are mounted with 225/55 Continental EcoContact 6 tires. The car is equipped with Automatic Slip Control (ASR), and braking is handled by four-wheel ventilated discs.
The seating surfaces are trimmed in black leather and Karo cloth (071), the latter of which extends to the door panels. Burled wood trim complements the dashboard, center console, and door panels, while amenities include heated power-adjustable front seats, automatic climate control, a power-adjustable steering column, dual front airbags, and cruise control. A US-specification Becker radio with a Bluetooth retrofit has been added, and the removed European radio is included in the sale. The headliner sags.
The four-spoke leather-wrapped steering wheel frames a 260-km/h speedometer, a tachometer with a 6k-rpm redline, an analog clock, and gauges for oil pressure, coolant temperature, and fuel level. The six-digit odometer shows 195k kilometers (~121k miles), approximately 2k of which were added under current ownership.
The 5.0-liter M119 DOHC V8 was factory rated at 322 horsepower and 354 lb-ft of torque. The distributor caps, rotors, and ignition coils were replaced in December 2024, and the neutral safety switch and battery were replaced in September of that year. The seller tells us that the wiring harness has a date code from 2012. Corrosion is noted on one of the radiator supports.
Power is sent to the rear wheels through a four-speed automatic transmission, and the shifter bushings were replaced in January 2024. Additional photographs of the underside are shown in the gallery below. The Carfax report shows no accidents or damage because there is zero data from the 32 years the car was in Europe.
The vehicle has not been inspected by the California Bureau of Automotive Repair or the Air Resources Board.
- I know, I know but..
