That's a whole different can of worms. Two of my favorite sounds in the world are the opening/closing of a G-wagen door, and a V126 (560SEL) door.Klink's favorite noise is the opening and closing of the G-wagon doors.
I'm partial to the pssssh-click of the closing assist on the 140. Yeah, I know the closing assist is problematic and complicated, but it's sooooo nice when working properly! Shame it was never available on the 124, so no chance of a reasonable-effort retrofit.That's a whole different can of worms. Two of my favorite sounds in the world are the opening/closing of a G-wagen door, and a V126 (560SEL) door.
Never owned a 140, so I cannot compare.
Here’s the final product, mounted on my garage shop wall above the E500’s home.
Currently collecting another batch of trunk logos to add to the collection.
As I’ve stated in the past, “Many Diesels died to bring us this information” .....![]()
Did anyone catch the exceedingly rare ("unicorn") badge in the lower one-third of my badge display?
| Car System | Code(s) | Code Interp | GVZ notes |
| LH (fuel injection) | None | No codes / system normal | |
| DM (diagnostic module) | Codes 4, 5 | Code 4 - Air injection system inoperative Code 5 - Exhaust gas recirculation system inoperative | I have been getting these codes for years, and they trip the CHECK ENGINE light. I believe I have a clogged EGR tube where it goes into the intake manifold at the ETA, and this is blocking air from being injected into the intake air. IMHO there is no performance issue in the actual running of the car from this, but I do need to pull everything off of the top end of the engine and fix it. |
| BM (basic module) | None | No codes / system normal | |
| DI (distributor ignition) | Codes 2, 8, 11 | Code 2 - Max retard has been reached on at least one cylinder Code 8 - Transmission overload protection switch does not close Code 11 - Reference resistor defective | I believe these are bogus codes, through IIRC the Code 8 is a new code that I've not seen before. Code 11 is a code I've gotten forever, which I don't worry about, because my reference resistor on the EZL has been modified as part of the BergWerks NOS installation. This code goes away when I replace the modified resistor with a non-modified one. |
| EA/CC/ISC (electronic accelerator, cruise control, idle speed control) | Codes 007, 096, 224 | Code 007 - N4/1 control module or ETA or neutral safety switch faulty Code 096 - Starter lock-out/backup switch (NSS) faulty Code 224 - S29/3 closed throttle position switch faulty | I believe all of these codes were caused by the bad NSS, before I replaced it earlier this year. All codes have been reset and I will watch to see if they come back. Note that these are the "detailed" three-digit codes, not the simple codes also available via the "blink" reader. |
| EZL (ignition computer) | None | No codes / system normal | |
| SRS (supplemental restraint system) | None | No codes / system normal | Generally I never see a code on this system unless I disconnect the airbag system elecrically when working on the steering wheel or such. |
| ACC (automatic climate control) | None | No codes / system normal | |
| ABS + ASR (brakes and traction control) | None | No codes / system normal | |
I am not convinced that the fan clutch is the cause of the problem.
Electronic countermeasures are legal in Maryland
I forgot to mention when I posted this shot, what was playing on the ICE at the time:View attachment 90026
Today I took the E500 out for a fall drive of about 125 miles on the Maryland roads.
Here is a shot blasting down MD-32, as it cuts directly through the middle of National Security Agency (NSA) headquarters at Ft. Meade, MD.
Temp: perfect
Speed: perfect
I don't see 1000sel on there!
Started making my MB logo “wall art” piece. I got a few pieces mounted, but ran out of glue gun sticks. So, will get more of them tomorrow.
You can see from the second photo how many more logos I have yet to mount.
I offset the round MB “trunk Star” logo and then started arranging logos radiating out from it like rays of light.
I think it will turn out pretty nice, when done. It’s a lot of fun making it !! The 4’ square piece of plywood is going to be totally covered in logos when I’m all done !!
View attachment 101849 View attachment 101850
I would TOTALLY make one, and would sell it for $100 USD.I don't see 1000sel on there!![]()
Had a pleasant surprise about three hours ago here....it was VERY damn loud.
![[500Eboard] D244981D-8BA4-4A68-BB1A-94437CFC69F0.jpeg [500Eboard] D244981D-8BA4-4A68-BB1A-94437CFC69F0.jpeg](https://www.500eboard.co/forums/data/attachments/103/103815-c5f5d1367b8b05710a8fb830512cc7ec.jpg?hash=xfXRNnuLBX)
Just came across an old post from the good old days .....
GVZ Euro Tour 2006: June 2006
gvzeurotour2006.blogspot.com
