Variable Valve Timing Solenoid: Description and Operation
Camshaft Timing Adjuster:
PURPOSE
The camshaft solenoids (Y49) enable the LH control module to specifically tune the intake valve timing for improved torque, volumetric efficiency, and driveability.
OPERATION
Camshaft Timing Advanced:
When the camshaft adjusting solenoids are energized the intake camshafts are turned 20° of crankshaft rotation in the advanced direction.
Camshaft Timing Retarded:
When the LH control module removes the current to the solenoids the camshafts return to the retarded position. The camshaft position sensor monitors camshaft position as an input parameter for the EZL/AKR control module.
