Front Cover Installed
- Remove Distributor Driver (also known as "Follower at Camshaft").
- Fit insertion sleeve (7) on to exhaust camshaft (10), special tool 119 589 00 14 00.
- Coat sealing lip of radial seal (1) with engine oil.
CAUTION: Do not use grease. Grease prevents the return delivery swirl on the sealing lip of the radial shaft seal (1) from transporting back the engine oil.
- Fit radial shaft seal (1) onto insertion sleeve (7).
- Press radial shaft seal (1) in with sleeve (8) (shop-made) to size "A" = 5 mm".
NOTE: The radial shaft seal (1) must be positioned vertically to the camshaft (10) in order to provide a proper seal.
- Remove holder of shield caps of high tension distributors.
- Press radial shaft seal (1) out with a screwdriver.
CAUTION: Do not damage camshaft (10) and mounting hole for radial shaft seal (1).
Special tools, Tools and Equipment
