Front Cover Removed
- Front covers at top removed. Service and Repair
- Press radial shaft seal out with a screwdriver.
CAUTION: Do not damage mounting hole for the radial shaft seal.
- Fit radial shaft seal (1) onto drift (01) 119 589 01 15 00.
- Press radial shaft seal in with drift (01).
NOTE: The insertion depth of 5 mm is obtained by using the drift (01).
