Ventilation Switch: Testing and Inspection
Fresh/Recirculated Air Switch Location:
1. Remove the ACC control unit. Refer to COMPONENT REPLACEMENT AND REPAIR PROCEDURES.
2. Carefully pull out the switch.
3. Disconnect the electrical connector from the switch.
Fresh/Recirculated Air Switch Testing:
4. Connect an ohmmeter between terminals 3 and 4.
Fresh Air/Recirculation Switch Testing:
5. Depress the symbol side of the switch ("ON"). The resistance should be:
0 - 1 ohm
6. Release switch. The resistance should be:
Infinite resistance
7. Connect the ohmmeter to terminals 2 and 4.
8. Depress the non-symbol side of the switch ("OFF"). The resistance should be:
Infinite resistance
9. Release switch. The resistance should be:
0 - 1 ohm
If the correct resistance is not obtained, replace the switch.
