BDM (Oil Evacuation Equipment)
The BDM oil extraction equipment is designed to extract waste oil via the oil dipstick of the engine, BDM's MB adapter (Pat. Pending) with collet lock for 8 mm (5/16") adapter hoses.
^ The unit consists of BDM Engineering's Stainless Steel Oil Recovery Unit of five gallon capacity.
^ Several adaptor hoses are included.
^ Fluid level indicator.
^ The unit can extract 4 to 11 quarts of warm waste oil in two to five minutes.
^ All replacement parts are sold separately with the exception of the Vacuum Generator. BDM offers a tandem unit: oil-coolant.
Accessories:
BDM Stainless Steel Tandem Oil and Coolant Recovery System
Technical Data:
Dimensions:
Width: 9 inches (230 mm)
Height: 24 inches (610 mm)
Weight: 14 lbs.
Air pressure Data:
Required air pressure: 70 psi, regulator supplied
Air press. Connection: Automotive Air Hose connector
Air consumption: 2.0 CFM @ 70 psi
BDM Engineering's Stainless Steel Vacuum Generator:
Vacuum generated: 28 inches of vacuum @ 3.1 CFM
Regulated via: 70 psi regulator
Silenced via: replaceable ABS Plastic silencer with 1/4 inch pipe thread.
