RAASM (Oil Evacuation Equipment)
The RAASM # 43091 "Aspiroil" is designed to extract spent fluids through the dipstick opening.
^ The unit rolls on 2 rigid and 2 swivel steering casters, which are lockable.
^ A graduated transparent bowl (capacity of 8 liters) is mounted above the waste oil reservoir, to show the quantity of waste oil extracted, as well as allow a visual inspection of the waste oil extracted.
^ The unit has a 90 liter reservoir which holds the extracted waste oil, along with an oil level indicator.
^ A removal tool tray for the placement of tools needed to perform the job.
^ Suction probes are provided for use to extract waste oil from other components such as the rear axle assembly.
^ Extraction capacity after creating a vacuum in the reservoir: 55-60 liters of waste oil.
^ Extraction capacity with hot oil (70/80°C) and a probe diameter of 6 mm: 1.5 - 2.0 liters per minute.
^ A full set of flexible/non-flexible suction probes to extract waste oil.
^ Extraction of waste oil from unit reservoir is air operated at approx. 7 psi.
Specifications:
Width: 25 inches (diameter)
Height: 51 inches
Weight: 80 lbs. (empty)
Reservoir capacity: 23.7 gallons (90 liters)
Globe dimensions: 9" width X 11" height (230 mm X 280 mm)
Globe capacity: 8.5 quarts (8.0 liters)
Extractor hose length: 78 inches (1980 mm)
Fluid transfer hose length: 80 inches (2032 mm)
Activation time: 3 - 4 minutes
Oil suction operation capacity 47 56 quarts
with one operation:
Air pressure Data:
Air requirement for activation: 100 psi
Air requirement for emptying: 7 - 14 psi
Additional Operational Information:
The technician activates the unit by simply connecting shop air for 3-4 minutes. (*TIP: when depressurizing the unit, open the valve between globe and reservoir tank.) This creates a vacuum in both the globe and the tank. Then close the valve after unit is fully charged. When extraction of one vehicle is completed, open the dump valve and the vacuum in the tank will automatically recharge the globe while the oil is being transferred into the holding tank. To empty the unit, close the valve between the globe and the reservoir, then charge the unit with 7 - 5 psi of shop air, move unit to bulk waste oil holding tank, place the hooked hose in the tank, open the exhaust valve and it will automatically empty.
