Policy - Fluke Meter Approved
REF. NO. MBNA 58/87ADATE: April 1996
(supersedes S.I. MBNA 58/87, February 1996)
TO: OUR MERCEDES-BENZ PASSENGER CAR DEALERS
Revised:
Update to reflect prices for Optional Accessories and revised text.
SUBJECT:
ADDITIONAL FLUKE METER APPROVED FOR STANDARD EQUIPMENT PROGRAM
MBNA has approved the use of the Fluke model 98 Automotive Scopemeter(R) (Figure 1)
The Fluke model 98 Automotive Scopemeter(R) offers some features not found in the previous Fluke 97 model.
^ Menu: pull-down menus let you pick basic test. Meter sets up test, guides you through connections.
^ Flight recorder mode: captures readings in three ways, expanded over Fluke model 97.
^ Simplified operation: pre-programmed pointer key allows quick movement through flight recorder.
^ Information key: touch key for detailed description of any function in menu.
^ Smooth: adjustable smoothing to eliminate extraneous noise from signals being tested.
^ Save/recall: save waveforms for later recall by pressing key, freeze waveform to save or print.
^ Language: menus, help screens and manual in two languages: English and Spanish.
The Fluke 98 Automotive ScopeMeter(R) is supplied with the following standard equipment (Figure 2):
^ Yellow protective holster
^ Hardcase with pouches
^ AC power adapter/battery charger
^ Shielded test lead sets:
2 mm adapter, 4 mm adapter,
backprobe pins,
wide jaw alligator clip set,
ground wire with banana plug,
02 adapter.
^ Capacitive pickup
^ Inductive pickup
^ 2 BNC leads
^ Ground lead
^ Extension ground lead
^ Demonstration board with 9 volt battery (automotive signal demonstrator)
^ User's manual
Optional Accessories Ordering Information
Refer to the table for available Optional Accessories and prices for Fluke 98 Automotive Scope Meter(R):
To order the Fluke 98 Automotive ScopeMeter� and optional accessories Mercedes-Benz dealers may:
1. Place their order directly Kent-Moore using the MBNA form S-0426-000 (Rev. 1/92) and a CHECK for the purchase amount to:
Kent-Moore Tool Division
28635 Mound Road
Warren, Michigan 48092-3499
2. Place their order directly to Kent-Moore using these toll-free numbers:
Phone: 1-800-345-2233
Fax: 1-800-578-7375
Mercedes-Benz dealers must identify themselves as a franchised Mercedes-Benz dealer and supply their dealer code number in order to obtain the DEALER NET PRICE. A CHECK for the purchase amount must accompany the order or be provided to Kent-Moore to expedite the order.
Please note that after sales service and repair of all Fluke products will continue to be processed as before via:
John Fluke Manufacturing Co., Inc
1150 West Euclid Ave.
Palatine, Illinois 60067
Phone: 847-705-0500
Equipment Tool Ordering Information
Additional Fluke items are still available as per following table. These items may be ordered directly from Kent-Moore Tool Division, using the procedure noted above.
