Air Temperature Sensor ( Ambient / Intake ): Service and Repair
Intake Air Temperature Sensor Replacement:
1. Unplug electrical connector at intake air temperature sensor (B17/7).
2. Check/replace O-ring.
3. Remove the intake air temperature sensor (B17/7) by turning it to the left.
4. Install in reverse order.
5. Extract and reset fuel injection control module diagnostic trouble code memory.
NOTE: Stored trouble codes may be caused by detaching cables and/or repair work.
