Crankshaft Position Sensor: Description and Operation
Crankshaft Position Sensor Location:
PURPOSE AND LOCATION
The crankshaft position sensor (L5) registers the crankshaft position and engine speed. The position sensor is mounted to the crankcase near the starter flange. The sensor body projects through the crankcase very near to the segments on the flywheel/drive plate. There is no contact between the segments or the position sensor.
Segment Wheel With Magnets:
OPERATION
With the engine running, the four segments which are positioned 90° apart pass by the position sensor. Due to induction, an alternating voltage is generated in the position sensor. The peak voltage is approx. 1.5 volts at starting speed. The voltage rises with increasing speed to approx. 3 volts at 1200 rpm.
Fig. 25 Crankshaft Position Sensor Signal:
t1 = First Segment
t2 = Second Segment
t3 = Third Segment
t4 = Fourth Segment
d = Period for one crankshaft rotation
The crankshaft position is recognized from the voltage signals which are produced. The segment front edge generates a negative voltage signal. The segment rear edge generates a positive voltage signal. Engine speed is determined by measuring the period (d) which is equal to one crankshaft revolution.
SIGNAL
This AC voltage signal is used by the EZL/AKR control module and transmitted via the controller area network (CAN) to the LH control module.
