Manifold Pressure/Vacuum Sensor: Description and Operation
Intake Manifold Pressure Sensor In EZL/AKR Control Unit:
PURPOSE AND LOCATION
The pressure sensor, located in the EZL/AKR control module (N1/3), detects the intake manifold pressure. This signal is sent from the EZL/AKR control module to the LH control module via the controller area network (CAN).
This information is used for the following:
^ Engine start-up to about 600 RPM
^ "Limp home mode" when air mass sensor is defective
